Is it possible to put parts for a neon 2.4L in a 2.4L Stratus motor, or can engines be swap with an srt-4?
Re: Is it posible to ......
you can do a cross reference on like autozone, and see if #'s match up to what you want to swap.
Thanks vamc do u have any idea were i can get parts to install an autostick?
Parts, i think you will need a whole new transmission for that one. Are you tring to convert a auto to an auto w/ and autostick? Is that correct?
Re: Re: Is it posible to ......
You will need the shifter and a new trans control computer. The transmission is the same. You may need to do some extra wiring to connect the shift up/down switches to the contoller. Depending on the year (I did not see it in your post), you may have to have the VIN flashed. Since the Stratus didn't have a factory option for Autostick with the 2.4, you will have to use a V6 trans control computer. Your automatic shift patterns will not match the engine output very well because of the output differences between the two engines. The Automatic shifting may not even be useable and you will have to manually shift almost all of the time.
I still think its a different transmission. automatic transmission have a 4 speend and the auto stick had 5. one more band in the transmission.
Is this a 2-door (Mitsubishi built) Dodge Stratus or a 4-door (Chrysler built) Dodge Stratus? My references are for the Chrysler built Dodge Stratus. The Auto stick is only 4-speed but has 6 possible combinations of forward gearing. 1,2,3,4 (obvious) and 3-TQ locked and 4-TQ locked.
Mine are for the 2 door.
Wait a min......they come down there same assembley(sp) line, they are both american not Mitsubishi built. Both have some electronics and some german influence, but both are more or less the same. same transmissions, the weight is different and a little longer for the 4 doors. just a quick thought.
The 4-door and the convertible are from Chrysler, the 2-door hardtop is Mitsubishi. Both have a 2.4l available but they are totaly different engines. If you check out the v6's the Chrysler built Stratus' have a 2.7l Chrysler engine the 2-door hardtop has a 3.0 liter Mitsu. Some of the parts are the same as per Chrysler spec, I believe that the auto transmissions are all Chrysler, as the Mitsu autos are even more junk the Chryslers.
Thats true, Have a happy thanksgiving tomarrow.
Now, back to your original question, NO.
You have a Mitsubishi and the SRT and Neon is Chrysler, the parts for the engines do not interchange due to the fact that the engines are NOT related (even though they are both 2.4l in size) or built by the same company. If you had a 4-door... there are possibilities. |
No! Some things will interchange. Plug wires will interchange. Plugs will not. the coile pack will interchange. It depends what it is. It just depends. yes you are correct and they are both 2.4. but they do shair simmular things. just a few thing though. Before you do anything, crossreference things before you do it.
That a reach VAMC, I can take 4 plug wires off of my 6 cylinder Jeep and put of them on most any 4 cylinder in the neighborhood.
With a 2-door Stratus you have no support from the Dodge guys because it is built by Mitsubishi and you have no support from the Misubishi Guys because a lot of the parts are mixed Mitsu and Chrysler. I believe the term is "Red Headed Step Child". |
