Old 11-15-2005, 12:51 AM
Blkhrt51 Blkhrt51 is offline
Humming in engine
When I come to stop I hear a humming or something comeing from my engine, but when I start to accelerate it goes away. Any one know what might cause this?
Old 11-15-2005, 06:48 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Have you popped your hood to listen? One guess could be the clutch fan... (A guess)
Old 11-15-2005, 12:06 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
....or a bad tensioner pully, idler pully, bad alternator bearings, you have to look and listen under the hood....
Old 11-15-2005, 01:26 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Humming in engine
Is it more of a whining noise?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-15-2005, 05:25 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
or you could be hearing the fuel pump at idel
Old 11-15-2005, 06:44 PM
DonSor DonSor is offline
Without knowing what car it is it might be that when you accelerate you just don't hear the humming noise over the engine. As everyone else suggested pop the hood and see where the noise is coming from. Certainly not in the drive train if you're not moving. Try squirting water arount pulleys and see if there is any change. At this point I would venture to guess that one of your rotating accessories has bearings going bad. Ex: Alternator, A/C, Power Steering, fan clutch of course unless you have electric radiator fan, and maybe the water pump.
Old 11-15-2005, 08:40 PM
its a 97 lt. and when I pop the hood i cant really pin point to exact source of the sound, but it does go away when i accelerate.
Old 11-15-2005, 08:51 PM
I presume you meant accelerate in speed while driving as opposed to just gunning the engine. As I suggested before try squirting water with a spray bottle at the pulleys. Borrow an engine stethoscope and start probing. Have someone change engine rpm while you listen. S-10 are rea wheel drives and they are not as bad to inspect as front wheel drive vehicles.
Old 11-15-2005, 09:01 PM
BlazerLT's Avatar
AF -Advisor
Does it go away when you rev the engine?
Old 11-15-2005, 09:42 PM
yes it stops when i rev the engine. but when it starts to fall back to idle it starts again.
Old 11-15-2005, 10:17 PM
The only things that I know of whereby something changes from rev up to idle are: A/C, water pump, fan clutch if equipped, power steering, and the alternator. I presume you had the A/C off. water pump problems don't hum, it'll be more like a squeal. Power steering noise will be noticeable when you turn your wheels, and alas! the alternator whick could be producing the AC hum called magnetostriction. Anyway you can take the alternator out of the circuit. Hard to do if you have serpentine belt. Might be worth the try.
Old 11-15-2005, 11:04 PM
BlazerLT's Avatar
AF -Advisor
Need to know more about this hum.
Is it a high pitched whine or what exactly is it?
Old 11-15-2005, 11:32 PM
it is a low hum. I think it might be the alternator due to some electrical stuff that also is going on. The lights sometime dim and go back to normal, but this happnes only sometimes and not when the noise is made. Its really weird to try and describe a hum. It sounds like it has intervals in it ( if that makes any sence ) and is not that loud in the cab, but you can still hear it. When i pop the hood its a low cracking hum i guess.
Old 11-15-2005, 11:37 PM
BlazerLT's Avatar
AF -Advisor
does it seen to happen more when you have the climate controls set to defrost?
Old 11-16-2005, 02:12 AM
No i dont use those, I live in az.
