Old 11-14-2005, 04:58 PM
strix9 strix9 is offline
removing 700r4
I got my rebuild kit the other day so Im almost ready to get going on it but Im not sure about a couple things. In the chiltons manual the last step of the removal says to support the engine using chevrolet special tool BT-6424 or its equivalent. I looked all over the internet and couldnt get any info on it. What is that thing? Also how would I tell if I needed a new torque converter? Thanks
Old 11-14-2005, 05:10 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: removing 700r4
or equivelant:
cherry picker or jack stands and a strategically placed hunk of lumber
Old 11-14-2005, 05:17 PM
lol. Thats what I thought. Thanks
Old 11-14-2005, 08:27 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: removing 700r4
A general rule of thumb...if you rebuild it, replace the torque converter, in case junk got into it. ALSO, if it has a transmission cooler, flush it out good to remove any debris that may have gotten in it.
Old 11-15-2005, 02:24 AM
Morley Morley is offline
To remove the trans DO NOT support the engine. Support the trans on a trans jack and slowly let it down so you can get at the 6 mount bolts with a 4 foot long extenstion and 9/16" universal socket. Once you have everything off and the bolts out, jack the trans back up until the engine is about level and then slide the trans back until it is free from the engine (remember to remove the TC to flex plate bolts). The engine will remain level all on its own without any further support with the trans off of it.
This is the voice of experience speaking, I just did a trans R&R in my 91 'Bird.
Old 11-15-2005, 10:12 AM
wrightz28's Avatar
Re: removing 700r4
Refer to "engine swap need help" thread by camaro84.
I find it much easier to tilt the motor back against the firewall. to eash their own, as long as it gets done.
