Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-14-2005, 02:04 PM
89Foxbody 89Foxbody is offline
High Nox
Hey I recently failed smog I have a 65mm throttle body, JBA headers, X-pipes, and 3.55 gears. I also have an aftermarket water temp and oil pressure guage. Here is what i got.
@15mph
%CO2: 9.5
%02 : 7.1
HC: 40
(MAX 121 AVE 31)
CO: 0
(MAX .76 AVE .10)
Nox: 1104
(Max 807 Ave 237)
@25mph
%CO2: 9.0
%02 : 7.7
HC: 26
(MAX 96 AVE 20)
CO: 0
(MAX .65 AVE .09)
Nox: 954
(Max 746 Ave 199)
Now, would my aftermarket temp gauge make the computer think the engine is always cold, thus advancing the timing and causing more nox, since my stock sensor is not connected? Or does the computer recieve engine temp from another source?
If thats not it, what could be causing my high nox and almost NO CO. Could it be a lean mixture, or possible intake leak?
Thanks.
Old 11-15-2005, 11:50 PM
dogbreath077 dogbreath077 is offline
Re: High Nox
Connect up the stock sensor, and then retest. I'm surprised they ran the test with it disconnected.
