Old 11-14-2005, 12:28 PM
altered.state altered.state is offline
Send a message via MSN to altered.state
VAlve Lifters
have a 2002 grand am se v6 been having all kinds of trouble with rad a friend of mine told me to try bars leak , so i did now 3 days later i have a knocking noise coming from the motor , another friend of mine that knows alot more than i do told me it was the vavle lifters thats one is sticking , is there any i can add into my oil when i do a oil chnage that might help out , or is recomended
Thanks
Old 11-14-2005, 01:54 PM
DonSor DonSor is offline
Re: VAlve Lifters
If your lifters were gummy, you don't want "Bars Leak". They do have some oil additive that are advertised to do wonders for a sticking valve. I have reservations but it may be worth a try. Otherwise you will need a "head job".
Old 11-14-2005, 06:38 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: VAlve Lifters
Is there any possibility that some of the bars may have gotten into the oil. If so you will probably have more than lifter issues. If you have water in the oil then you will probably end up with an engine rebuild or replacement. Lifters in a V6 don't knock anyway they tap tap tap. A knock usually means that a rod bearing or main bearing is about to go or that a rod is about to break. I would have a mechanic look at it to see what is happening.
Old 11-14-2005, 07:27 PM
Re: VAlve Lifters
sorry about that i used bars leak for my rad leak , and yes its more of a tap tap tap, after warming up for about 5-10 mins the tap tap tap goes away
Old 11-15-2005, 05:27 AM
Pontiac Guy
Re: VAlve Lifters
Check your oil and make sure that the level is proper and that the oil doesn't look milky or extremely black. You mentioned major radiator issues and if you overheated the engine there is a possibility that the oil has been cooked and needs to be replaced. You may also want to try a slightly thicker oil to see if the lifter noise goes away.
