Old 11-14-2005, 11:42 AM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
WHat should I do about this?
It looks like a barbedwire scratch. Anythoughts? Can it be wet sanded?
Click on the picture to see it larger
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
Old 11-14-2005, 02:19 PM
383stroker_1 383stroker_1 is offline
Re: WHat should I do about this?
get some color match touch up paint. This area will not be that noticable.
Old 11-14-2005, 02:20 PM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Not sure, but I have a few scratches like that I would like to get rid of. Hopefully someone will know.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 11-14-2005, 02:51 PM
I checked with the GM dealer today and he said its a Medium Metallic Pearl Green. He was out of stock on the 5 oz. aresol but said a good paint source could make me a can to match. I got to thinking.....
Hmmm. Maybe I could do my intake cover with whats left
PS I do not want to use those dab pens ever agin. They are a mess to sand etc.
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
Old 11-14-2005, 03:36 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
Use a scratch removing polish. It might not work tho cz those look pretty deep. If it doesnt then i recommend getting some touch up paint. What do u mean by wet sanding it?
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
Old 11-14-2005, 04:56 PM
Re: Re: WHat should I do about this?
some body work requires wet sanding. Using a fine grit (600-3000) paper that has been soaked overnight in water. Then while you sand you mist the area or use a water source to continually lubricate the paint as you sand. It keeps the sand paper from loading up with paint.
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
Old 11-14-2005, 05:57 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
I'm not sure those little touch up tubes are meant to be sanded after using them. I'm talking about the little ones from the dealer with the little brush in them
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 11-14-2005, 07:17 PM
yeah thats what I mean. Those dab products. I am going to find a small can of the color and do a test sample and see if it matches. (spray a piece of primered metal)
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
