Old 11-14-2005, 09:17 AM
mycrazys10 mycrazys10 is offline
Differential Oil
Hey guys! Listen, I have a 1997 s-10 (2wd) that I am about to change the rear differential cover on. My question is- how much gear oil do I put back in afterward? I bought 2 quarts of 8090. Do I fill until I cant get anymore in, or is there a certain amout I should put in and be careful not to overfill. Thanks everyone.......
Old 11-14-2005, 12:04 PM
whitetrash982 whitetrash982 is offline
Send a message via AIM to whitetrash982
fill it till you cant get anymore in , the level inside the diff should be even with the bottom of the fill hole , usually aroudn 2 1\2 qts
Old 08-08-2006, 08:12 AM
neuf62 neuf62 is offline
Re: Differential Oil
where is the fill hole, i was looking around and didn't see anything that stood out. i am running a 87 s-10
Old 08-12-2006, 12:07 AM
fergys_super10 fergys_super10 is offline
Thumbs up Re: Differential Oil
it should be near the bottom usually in the middle of the cover and you fill until you can touch with the tip of your finger overfill causing foaming and breakdown of gear oil REALLY BAD TO OVERFILL
Old 08-12-2006, 05:33 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
It's not on the cover. The plug is towards the top on the side of the pumpkin. It uses a square drive. But as said, fill it to the hole.
Be sure when replaceing it you clean ALL gasket material off the pumpkin and the cover. Use a razor blade and if needed, sand paper.
Spray the inside of the pimpkin and cover with brake clean to ensure good clenliness.
