Old 11-14-2005, 07:53 AM
jetaylorpb's Avatar
jetaylorpb jetaylorpb is offline
97 Blazer Ignition Problem
Drove it home one night and every thing was fine, or so it seemed.
Next morning the wife tries to start it and it won't. I get home from work and try. Now here are the symptoms: my key is stuck in the ignition, the steering wheel will not lock when turned and the shift lever is stuck in park no matter how turn the key. The battery is also completely dead.
I'm thinking the ignition on the steering column needs to be replaced? Is that easily done?
www.pubcrawling.org www.cockerownersgroup.com www.emrpaintball.com www.scenarioball.com www.atomicordnance.com
Old 11-14-2005, 08:41 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 Blazer Ignition Problem
Depends on how handy you are and if you have the proper repir manuals to do the job.
1997's do have the ignition switch failure. The ignition switch is a black module in the column, not the key tumbler itself.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-14-2005, 08:55 AM
jetaylorpb's Avatar
The ignition switch was replaced about 6 months ago. When that went I was just not able to start it, nothing like what is happening now.
Could the ignition switch failing have multiple symptoms and this being one of them? I would think an ignition switch just bought 6 months ago would not have the same defects that causes the originals to fail so much.
What is the exact mechanism that allows you to shift out of park? Is it mechanical in the ignition tumbler or an electrical process? I wonder if I got some juice into the battery if that would allow me to get it out of park so I could tow it myself to the garage so I wouldn't have to pay someone to tow it, where I live it would cost about $75 just for the tow.
Old 11-14-2005, 09:07 AM
Officer Redneck's Avatar
Officer Redneck Officer Redneck is offline
Send a message via MSN to Officer Redneck
If the battery goes dead, it will do all the things you explained. Jump it or better yet charge it over night and every thing should work again. My '97 did the same thing about a month ago.
2003 Honda Element EX
2002 Kia Spectra (can't "Improve" or wife will kill me)
1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot)
" Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White"
http://www.myspace.com/officer_redneck
Old 11-14-2005, 09:59 AM
BlazerLT's Avatar
AF -Advisor
But we need ot find the cause of this plus why he can't get his key out.
Old 11-14-2005, 10:12 AM
jetaylorpb's Avatar
The belt was squeeking some so maybe it's not turning the alternator enough to charge the battery. I was going to have them replace it when I got it inspected but wouldn't you know my wife was attempting to get it registered when she couldn't start it so it never got there.
Is the belt difficult to change? On my 86 S-10 its a peice of cake but the Blazer looks rather intricate and there isn't much room to work with. Keep in mind by the time I get home from work at night it is pitch black and 40 degrees, I don't have a garage and will be using a flashlight for lighting.
Still kind of odd that the key is stuck in the ignition. If I can get the thing to run I'll just leave it there.
Old 11-14-2005, 11:03 AM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: 97 Blazer Ignition Problem
Replacing the belt is really not hard to do. All you need is a 16mm socket and breaker bar. Pull back on the Belt tensioner remove old belt and install new one. Your belt routing diagram is on your fan shroud. Take about 5 minuets. Good Luck.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-14-2005, 11:58 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: Re: Re: 97 Blazer Ignition Problem
Gabe25, What do you use the 16mm socket for when changing the belt?
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 11-14-2005, 12:06 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
In order to get the key out, you need a good battery. There's a small 2 wire connector (part of the Ignition switch harness) attached to the key cylinder that allows the switch to turn back to the lock position that requires power (12v).
Replacing the belt is easy, just put a socket & ratchet on the tensioner, turn 1/4 turn to loosen the belt, slide it off, and install the new belt.
As stated above, about a five minute job and it's really quite easy.
Old 11-14-2005, 12:46 PM
BlazerLT's Avatar
AF -Advisor
I think the ke in the ignition is the cause of the drain.
Might be allowing some connections to stay live.
Old 11-14-2005, 12:52 PM
jetaylorpb's Avatar
The key was not stuck in the ignition when it first failed to start. My wife had tried that morning, the blazer wouldn't start but her key did not get stuck. When I got home that evening I tried and my key did get stuck.
I am going to try and take a half day from work to replace the belt and try and jump start it while the temp is still in the 50's and I have some daylight. I'll let you all know how it went tomorrow a.m..
Thanks for all the help so far.
Old 11-14-2005, 01:31 PM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Re: Re: Re: Re: 97 Blazer Ignition Problem
Got me wondering too. I've always used a ratchet to loosen the tensioner. I've owned a 96, 97 and currently a 99. The ratchet just goes in the square box on the tensioner.
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 11-14-2005, 03:56 PM
Gabe25's Avatar
On my "94" the bolt on the tensioner pully is 16mm. I just slip it on and pull. Belt off, Belt on. So simple.
Aloha
Gabe
My Fleet
Old 11-14-2005, 04:25 PM
blazee's Avatar
blazee blazee is offline
Problem?
Am I the only one that doesn't use any tools to change a belt?
Old 11-14-2005, 05:46 PM
BlazerLT's Avatar
AF -Advisor
I might have missed it, but has the battery been tested?
