mpg on the DIC
I was just wondering how accurate is the mpg setting on the DIC of a 98 grand prix gtp, do i need to push the rest buttion on the dic after i fill up so it can update my mpg or does it do that on its own???
Re: mpg on the DIC
No, you need to press reset after you fill up, otherwise, its giving you the cumulative average fuel economy since the button was ever last reset.
![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
Re: mpg on the DIC
ohh ok thought so, definetly have to remember that next time i fill up, it wont reset everything else all at once will it?
Re: Re: mpg on the DIC
Just make sure you're in the right mode such as avg econ when you do. ![]() ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
Re: mpg on the DIC
ohh ok, thanks!
