Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-13-2005, 10:01 PM
jpey00 jpey00 is offline
3400 interchange with newer engine
Sorry to bother you GA guys, but I didn't get any responses in the Venture section. Not too exciting I guess. I know one of you will be able to tell me. Thanks.
Hello,
I need some information. I need to know if a newer 3.4 liter engine can be installed in a 98 Venture? I know that the 3.4 was the same from 96-99, but it is difficult to find a low mileage used engine. Can I install a 01-05 3400 engine without too much problem. If need be, I donn't mind stripping it down to the long block. I am however concerned about the cam sensor. From 96-99 the cam sensor sync ring was a missing tooth design. 2000 went to a single tooth design and 2003 went to a 50/50 raised and lowered semi-circle design. If I use the sensor designed for the sync ring, willl it send the correct signal to the 98 ECM? Is there anything else that might give me problems? Please help. Thanks.
Old 11-15-2005, 11:15 PM
grand04amgt grand04amgt is offline
Send a message via AIM to grand04amgt
Re: 3400 interchange with newer engine
only 01-03 will fit of the newer ones
Old 11-15-2005, 11:19 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
What is wrong with the original engine? On mini-vans, it's easier to repair the original than replace the engine entirely (unless of course you threw a rod or broke a crank)
Old 11-16-2005, 06:26 PM
Re: Re: 3400 interchange with newer engine
Thanks for the reply. why only 01-03?
Old 11-16-2005, 06:28 PM
I believe the cam broke, oil pump went bad or shaft broke. Lots of noise and the oil light stays on.
Old 02-20-2007, 10:39 AM
black1992 black1992 is offline
99 grand am 3400 bad motor what will interchange?
Old 02-20-2007, 05:08 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Sorry black1992, but we dont bring up threads older then 3 months as outlined in the Community Participation Guidelines.
If you need help start your own thread and someone will help you out
And welcome to AF !
This is closed!
1999 Grand Am SS 3.4 OHV
Closed Thread
