Go Back   Automotive Forums Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 11-13-2005, 08:50 PM
zax89 zax89 is offline
Boosting
Hey guys i recently bought an 89 supra turbo and the dealer said that it had a boost adjuster Heres a Pic
can you take a look and tell me what ill need to know how much to go.
thanks
Old 11-13-2005, 11:47 PM
Yellow 13's Avatar
Yellow 13 Yellow 13 is offline
Send a message via AIM to Yellow 13
Re: Boosting
wtf? I want one...
Old 11-14-2005, 11:40 AM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: Boosting
Wow, its been a while since I have seen an old school boost controller. The guy that installed it has probably already tuned it. You should leave it alone. Messing with it could be hazardous to your motor. Modifications like this were done back before there were affordable aftermarket electronics to handle things. If you adjust that thing and raise your boost levels you should do it only if you are monitoring the AFR through a wide band system, and are monitoring boost levels through an aftermarket boost gauge. If you exceede the stock fuel system capacity you will turn your engine into a grenade. You also run the risk of turning your turbo into a grenade. The CT-26 self destructs at 14 PSI. It dosen't really live long at anything over 12.5 PSI. The more I think about it the more I have to say don't mess with it.
If you really want to modify the engine do it right. Get a metal head gasket, a new turbo system, a wide band O2 sensor controller, a piggy back fuel computer, an aftermarket boost gauge, bigger injectors, and an intercooler.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 11-14-2005, 11:42 AM
TcmaBoy's Avatar
AF - Advisor
Re: Re: Boosting
Originally Posted by Yellow 13
wtf? I want one...
No, you don't.
Old 11-14-2005, 02:50 PM
Yellow 13's Avatar
Re: Boosting
After that statement your right...I dont want one.
Old 11-16-2005, 04:01 PM
can you explain to me how i can take it off and return it to stock
thank you
Old 11-17-2005, 04:25 AM
djcrypt's Avatar
djcrypt djcrypt is offline
Re: Boosting
i dont think u need to take it off, just lower the boost. but if it has already been tuned to a higher psi, then your engine will be running very rich, i think.
***correct me if im wrong***
Old 11-17-2005, 10:49 AM
TcmaBoy's Avatar
AF - Advisor
Re: Re: Boosting
Not really. The ECU will see the lower air flow and adjust automatically. That map also only applies under WOT. Durring partial throttle cruise the ECU monitors AFR via the O2 sensor and trims the fuel mix to 14:1. ECUs are pretty good at trimming the mix. Where people run into trouble is when they start flowing more air than the fuel system can deliver.
Old 11-17-2005, 11:42 PM
the boost is actually lower so i was told not mess with so i cant return.
Old 03-04-2006, 12:38 AM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
Re: Boosting
what psi is a stock 1991 boosting? its like 6-7. I just want to be sure.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
