Warm starting problem?
I have a 99 Chevrolet with the 5.3. I can go out in the morning and it will fire right up. When I drive it for a while and then cut it off and then go back to crank it, the engine turns over and over and then when it fires the engine hesitates before coming to regular idle. It runs like normal on the road once it comes to regluar idle I took it to the local dealer and all they did was clean my fuel ports but it did absolutely no good. Is this problem due to the injecion pressure regluator? Thanks...
Re: Warm starting problem?
*sigh*
try the chevy section dude... this is nissan...
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
okay, here's what you do (it's only 3 easy steps!!!)
1). Write down your problem on a piece of paper 2). Fold it three times 3). Stick up your ass problem solved!!!!!! j/k man, yea try the chevy section being as this is the nissan forum
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
Thread Moved!
ZedEx Crew Member #4
