Old 11-13-2005, 04:35 PM
spivey-1 spivey-1 is offline
parking light ?
alright guys here is the problem, when i turn on my lights one parking light comes on and the other one wont, but when i turn on my turn signal the one that doesnt work before works, but only when i turn on the blinker. what would cause this. bulbs have been changed too.
Old 11-13-2005, 04:37 PM
parking light ?
by the way my truck is a 97 s-10 with a 2001 front end. 2.2l thanks
Old 11-13-2005, 08:10 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: parking light ?
Make sure you put the right bulbs in.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 11-14-2005, 01:47 PM
parking light ?
Im pretty sure the bulbs are the right ones. anything else that could be wrong. im thinking it is something electrical, maybe a short or something. I dont know. if it is a short in the wiring how do i fix it. thanks
Old 11-14-2005, 01:59 PM
hakogen's Avatar
hakogen hakogen is offline
Re: parking light ?
it sounds like a bad ground. there are a number of places where a bunch of wires come together (a block or harness) and mount to the frame of the vehicle (the ground). if the connection to the frame is bad then weird shit will happen like lights working and not working, etc. i had a 68 lemans as a little project a few years back - whenever you hit the brakes it would shut the radio off (it was blowing the radio fuse because of the short)
speaking of which - have you checked all your fuses? one might be almost dead, which wuold cause the rediculous shit to keep happening.
Old 11-14-2005, 07:02 PM
parking light ?
hey man i will try finding the ground, if not that would anything else cause this problem
Old 11-15-2005, 09:20 AM
hakogen's Avatar
Re: parking light ?
the harness that connects the p-light could be FUBAR.
the list goes on. start at the fuse block and check them all (you might have two different fuseblocks, one in the cab on the driver's side on the side of the dash - and one underhood.). from there, go to the malfunctioning light, check the plug on the back of it, and work your way back until you find a problem like a frayed wire, or corroded ground...
it's a bit time consuming, but it isnt difficult.
Old 11-15-2005, 09:48 AM
parking light ?
hey man thanks for the help, if i find the problem i will be sure to tell u what it was.
Old 11-15-2005, 11:02 AM
hakogen's Avatar
Re: parking light ?
hell, even if you dont find the problem let me know... no problem, btw.
good luck.
Old 11-22-2005, 04:26 PM
parking light ?
hakogen, i found the problem, had a wire pinched underneath the battery and it had burned up spliced it back together and whal la. fixed. thanks for your help. i hate bleeding people dry for answers and then not telling them how i fixed it so there it is thanks.
