Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-13-2005, 03:37 PM
cujo21 cujo21 is offline
1998 4Runner sputtering
I have 1998 4runner, 4cyl with 123K miles that has started to stall at low speeds and when idling. I am able to shift into neutral and restart it each time with no problems. It runs fine at normal and high speeds. I have changed the alternator, spark plugs, and had the fuel injectors cleaned. What else could be the problem? Is the fuel pump going bad?
cujo21
Old 11-13-2005, 09:38 PM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Do check your fuel pressure. 38-44 psi
There are sticky posts at the top of this forum with links to the 93 FSMs.
Fuel pressure regulator?
Check these in particular:
Just some ideas.
FUEL PUMP:
http://personal.utulsa.edu/~nathan-b...28fuelpump.pdf
FUEL PRESSURE REGULATOR:
http://personal.utulsa.edu/~nathan-b...30fuelpres.pdf
IDLE:
http://personal.utulsa.edu/~nathan-b.../5idleando.pdf
ENGINE:
http://personal.utulsa.edu/~nathan-b...sm/engine.html
FSM LINK:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Good Luck
