Old 11-13-2005, 02:42 PM
bluecamaro bluecamaro is offline
Question 81 camaro won't start
I tried to start my car today and it turned over but didn't start. Because it had been sitting for a couple of days I switched the iginiton off and pumped the gas pedal a couple of times. When I went to turn the ignition back on there was nothing. No clicking sound nothing! I have headlights which are bright which leads me to believe that it is not a battery problem. Any suggestions?? Thanks
Old 11-13-2005, 02:50 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Have you checked for spark?
Old 11-13-2005, 02:54 PM
Not yet. Will definitely be doing that. Also wondering if it could be a switch as you have to have the clutch engaged to start. Have to wait for the mechanic in the family to come home!
Old 11-13-2005, 05:28 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 81 camaro won't start
So its not even turning over. Right?
Also welcome to AF and the camaro forum
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-13-2005, 08:13 PM
Yep, not even turning over. When I first went to start it, it turned over, but because it had sat a couple of days I thought I hadn't given it enough gas to get started. I turned the ignition off, pumped the gas twice and when I went to restart....nothing!
Old 11-13-2005, 08:40 PM
FormulaLT1's Avatar
Fight the powwa!!!
Well, fuel pressure and ignition will have nothing to do with it not turning. Either your starter gear is jammed or your solenoid is dead or your battery is seriously low on the starting amps. I would take a look at the starter and see if the teeth are jammed into the flywheel. Good luck
