Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 11-13-2005, 12:49 PM
bman68 bman68 is offline
99 Grand Cherokee shifting problem
At first my tranny wasnt shifting out of 3rd so I pulled over turned the engine off for a minute turned it back on the check engine light came on then as I drove it it wouldnt shift out of first gear. I noticed the shifting problem as I was turning the corner I hit a big hole in the road in mid turn. The jeep was running fine all day until then could this be electrical
Old 11-15-2005, 10:25 AM
twright67 twright67 is offline
Re: 99 Grand Cherokee shifting problem
Have the code read... It is most likely the Output Speed Sensor on the Transmission... Replaced mine a couple months ago on my 99 Grand Cherokee...
Old 11-15-2005, 11:32 AM
Summett Summett is offline
Re: Re: 99 Grand Cherokee shifting problem
Same here! Exactly the same thing. If it is, replace it yourself...will save you ALOT of money.
Good Luck!
Old 11-17-2005, 02:47 PM
jeepfixitman jeepfixitman is offline
Send a message via AIM to jeepfixitman
output speed sensors on 42res if thats your tranny go out a lot!!! 13 dollar part though easy fix
Old 11-18-2005, 12:10 PM
goldjeep99 goldjeep99 is offline
I had similar problems with mine a couple of years ago. The Check engine light was on... Had dealer replace it for like $60... boy that was a surprise!
Old 11-20-2005, 02:28 AM
thats what it was output speed sensor thanks everyone
