Old 11-12-2005, 06:19 PM
vbicknell vbicknell is offline
Weird electical/starter problems in '90 Cherokee
My problems started with a bad starter. The thing wouldn't turn over, then I rapped on the starter with a hammer and it would start. This happened occassionally for a couple of weeks, then one time after turning the key, everything died, including the radio, lights, etc. I let it sit for a few hours and then it started up again. I put a new starter in and the problem wasn't fixed. I put the key in the run position and the radio, etc. would turn on, as soon as I tried to start it, everything died. I replaced the ignition switch, now there is no power anywhere. I had the battery checked, replaced the negative cable, cleaned the pos. I am at a total loss. Does anyone have any suggestions?
Old 11-22-2005, 08:34 PM
91indaworks 91indaworks is offline
Same problem in my 92
It is the nuetral saftey switch. It actually mounts to the outside of your tranny and is $$$$$.
The best way is to search jeepsunlimited.com for their fix of it.
Old 11-22-2005, 09:31 PM
Denny G Denny G is offline
Send a message via AIM to Denny G
Re: Weird electical/starter problems in '90 Cherokee
Neutral switch OR the load reduction relay?
Denny G
Old 11-23-2005, 11:00 AM
Saudade's Avatar
Saudade Saudade is offline
I have a suggestion. You put the ignition switch in wrong or broke something else in the process.
Go back under the dash and double check EVERYTHING. Make sure the connector is pushed on all the way. Make sure the switch was indexed properly when you put in the rod from the column.
Make sure no other connectors came apart while you were wrestling with everything under the dash.
If I sound harsh, I don't mean to be. Just been there done that myself.
Old 11-27-2005, 09:59 AM
vamc's Avatar
vamc vamc is offline
www.quadratec.com
this is also a good place to check out.
