Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-12-2005, 06:14 PM
brielly brielly is offline
oxygen sensors
For those who have replaced theirs- how difficult was it? I was under the truck today and it looks like the two before the cat are going to be hard to get to especially since i don't have access to a lift. Any tips on removal/instllation would be appreciated.
Old 11-12-2005, 06:34 PM
rodeo02 rodeo02 is offline
If you can change a sparkplug, you can r/r an oxygen sensor. I mail ordered an O2 sensor "socket" kit from oxygensensors.com. VERY handy kit as it gives you several options- depending on how the sensor is mounted. They will be difficult to loosen. The socket wrench took several blows with a big hammer to get an O2 sensor to break loose on my 2002 rodeo. It will take some more presuation if your rodeo is older.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-12-2005, 08:49 PM
anthonyn anthonyn is offline
Re: oxygen sensors
The 'how to' on a job like this is pretty obvious. But, the execution may be rather difficult depending on how 'stuck' the sensors are. I would go to autozone and borrow their oxygen sensor socket/wrench. Then at least try to see if you can loosen the sensors after spraying them with liquid wrench ahead of time. You may get lucky and be able to do it yourself. I gave up and took it to a shop and paid the guy to remove them. Even he broke a major sweat getting them off, and that's with the truck lifted over his head versus me on my back wresting with the wrench.
Old 11-12-2005, 09:47 PM
What looks difficult is getting to the sensors, getting the socket on it then having enough leverage/room to move to actually break it free. It looks pretty tight under here.
Old 11-13-2005, 10:07 AM
What year/engine/drivetrain? 3 of the 4 are not too bad on my 2002 3.2 4x4 auto. I think bank 1 sensor 1 is the toughest. Like I say, you may need a variety of sockets to get the job done. If you can source a 3 pc kit like this: https://www.automedicsupply.com/tool...47f7ed882e61d# , and a long breaker bar, you will get the job done easier.
G/luck
Joel
Old 11-13-2005, 01:54 PM
gray1g gray1g is offline
do these sensors have a max life? I have a 98 with 111,xxx miles and they haven't been replaced as far as I know. Should i not worry about it since I don't get a check engine light?
Old 11-13-2005, 02:48 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Dont worry about them until you have a problem. It is possible for them to get weak and cause a problem without trigering a CEL (especially on OBDI systems) but you would know there is a problem.
One thing to add. Make sure you use anti seize compount on any new O2 sensors you put in. Will make them easier to take back out next time.
