Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-12-2005, 05:39 PM
cpmudrunner cpmudrunner is offline
Angry Brake problems
I recently purchased a 2002 ranger 4wd w/ 4.0V6 & auto tranny. when first starting the truck and driving, the brake pedal feels pretty low and response is kind of weak. After driving for about 10 mins, brakes are fine. Dealership tech looked at the problem but determined nothing was wrong. I was ondering if anyone else had a similiar problem. Brakes were replaced and rotors turned on the front, and rears supposedly only "serviced". I thought maybe ajustng up the rears might help but not sure . Any advice? need more info?
Old 11-16-2005, 09:30 PM
fordin K fordin K is offline
I would check brake adjustment at rear first. then check if need to bleed.
Old 11-17-2005, 08:36 AM
korny351 korny351 is offline
Re: Brake problems
May sound a bit far-fetched, but it sounds like a vacuum problem. Possibly a restriction in the vacuum line to the brake booster. Something preventing the brake booster from receiving full vacuum at startup. Then as you drive vacuum increases to normal levels.
Old 11-22-2005, 08:17 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: Re: Brake problems
if it was that, he would have a stiff brake pedal
