Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-12-2005, 02:41 PM
WHODINI358 WHODINI358 is offline
Send a message via AIM to WHODINI358
Question Drivers side heater
I was wondering has anyone had any problems with the heating system in thier 200 LS? It does not get very cold here in Dallas so I havent used it much this year. I noticed the drivers side of the vants are taking up to about 30 minutes to heat to the temp that the passenger side has reached. I am talking the difference of like 85 degrees to about 65 degrees. If anyone has experinced this let me know what the cause of it is. Iam thinking one of the cats might be the problem I have replaced the thermostat, the housing and water outlet pipe and o-rings.
Old 11-14-2005, 08:13 AM
fry628's Avatar
fry628 fry628 is offline
There is a valve by the lower pass side of the radiator that controls the right and left heater valves and LS has had problems with the very thing you are talking about. To be honest I've changed a few and I can honestly say do not try this yourself unless you have lots of patience and moderate technical skill plus you have to have lots of tools. Do not try this with "the craftsman 2000" . Make sure you also have a extended squeeze clamp removal tool because some clamps have no room for regular pliers. I'm sure with lots of tequila and lots of prozac you'll do fine!
Certified Ford tech for 10 years
Old 11-17-2005, 08:49 PM
Re: Drivers side heater
You Wouldnt Happen To Know The Name Of The Valve By Any Chance?
Old 11-17-2005, 09:34 PM
lskoncepts's Avatar
lskoncepts lskoncepts is offline
Actually that sounds like your DATC (dual automatic temperature control) unit is bad. It's the part that sits underneath your radio. It's pretty common for those to go out.
Also, use a different font color next time if you don't mind. Your post was a little hard to read.
Ken Garrison
2001 Lincoln LSE
Pics of my 2001 Lincoln LSE!
LS Koncepts
Luxury Sedan Aftermarket Parts
