Old 11-12-2005, 02:14 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Exclamation Popping from front suspention
Ok, this has been going on for awhile. When ever i stop or go a popping sound comes from the front. Im shure its the sway bar b/c i just had the control arms replaced. The connections for the say bar look good but how do i lube the fitting? they dont have the bleeders that you hook on to. I think it is popping b/c they are dry. Thanks in advance for the help.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-13-2005, 03:07 PM
kahjdh's Avatar
Re: Popping from front suspention
anybody?
Current Cars:
Past Cars:
Old 11-13-2005, 04:06 PM
mohdc mohdc is offline
Lubing joint
I had similar issue with my 2001 Windstar. Following some of the earlier thread, I used a needle attachment for grease gun, and pumped grease into the boot on the anti-sway bar. I grease the anti-sway bar link attachment. The poping cracking noise has disappeared since then.
Make sure you do not over grease.
Old 11-13-2005, 04:20 PM
wiswind wiswind is offline
I have also used the grease needle.
There are other possible causes of popping sounds....but the grease needle is the cheapest.
Another is the subframe bushings......there are 4 of them.....They connect the subframe (which holds the front suspention) to the unibody. They can work loose. These have nuts that face down.
Another source of popping can be the bushing "pocket" where the rod for the front suspention connects to the subframe. There are 2 of these....and you see them from the front underside of the car. One is right by the oil filter....you will see 2 large nuts...and the threaded ends of the round suspention.....facing forward.
The solution is usually to have the bushing mounts welded to the subframe.
Old 11-13-2005, 08:34 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Re: Popping from front suspention
WisWind, and others
I had this piece come loose on my 93 Taurus. There was clunking going on. I took it out and took it to the Ford dealer. I didn't know it wasn't suppost to come out of the subframe. The dealer didn't have a clue what I had in my hand. I too had mine welded in.
Regards
Dan
Old 11-15-2005, 06:26 PM
busboy4 busboy4 is offline
Hi
My front suspension bushings are loose on my '96 and pop. I can, in my driveway, let off of the brake and roll very slowly forward "bouncing" the van by "fanning" the brake on and off. My bushings will pop every time. Conversely, I have also had the noise from the subframe bushings. I had to be actually driving, starting and stopping to hear it. I also felt it as the left rear subframe bushing is under the drivers feet. I changed mine which was not too difficult. I have not yet made it a priority to have the suspension bushing sleeves re-welded.
Good luck
Old 11-15-2005, 06:27 PM
Hi
Good luck
