Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 11-12-2005, 02:01 PM
L8R_H8R L8R_H8R is offline
Is it safe to run n2o on a stock engine?
i've been thinkin bout nitrous but my engine is a stock h23, is it safe to run nitrous on a stock engine?
At the time, McLaren was racing successfully with Honda engines, and it seemed logical to approach Honda for an engine meeting Murray's requirements. But the Japanese declined, feeling that they could not spare the capacity to develop such a project.
Old 11-12-2005, 04:53 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Is it safe to run n2o on a stock engine?
it really depends on the size of the shot, how it is done (wet or dry) and how often it is used....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-12-2005, 06:51 PM
i plan on getting wet, prolly 75-100 shot.
Old 11-12-2005, 07:03 PM
Schister66's Avatar
AF -Advisor
wet is safer because it injects fuel w/ the nitrous and most times has a tuning system along w/ the nitrous system. I don't think you'll have a problem, but i'm not claiming to be an expert at N2O....
Old 11-12-2005, 07:17 PM
thanks for the help, as long as i have a resonable chance of safley runnin n2o, then i'll probly get it.
Old 11-29-2005, 05:23 PM
singlecamscottie singlecamscottie is offline
Send a message via Yahoo to singlecamscottie
75-100 is a bit much to be safe...i would run 65wetshot... it's a 39 mm jet that goes right into the intake... just remember to retard your timing.. at least 2 degrees... i did 2.5 to be extra safe, only downside is that i'm boggin down up to 2500 rpm. but in a race you wont ever be in that rpm range.. and if you wanna bump it up to 75 shot, it's 4 degrees timing retard, and 7 degrees for 100 shot!!
[FONT=comic sans ms]d16y8 block/d16b6 vtec head...aka fastest mini me ive ever seen
and its all mine locked up in a 4door
[/font]
Old 11-29-2005, 05:33 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Re: Is it safe to run n2o on a stock engine?
this is a stupid statement, dont listen to it. while it is true you should retard your timing more as you increase your shot, an exact amount like he is saying is not accurate. thats his own personal judgement.
but i do agree that 75-100 is too much. i would run a 65 like he suggested.
Team Lonely Drivers
Old 11-29-2005, 08:55 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Ran a 75 shot for quite awhile on a B16. Follow the directions like it says, and you typically will not run into problems.
Retard timing 4 degrees, 2 heat ranges colder on your plugs, and always put in 91' octane fuel. And dont use it at every damn stoplight.
Old 11-30-2005, 02:38 AM
Przemir4g Przemir4g is offline
Can I also ask?
b16 in 4gen /stock/ and dry small shot /like nx incognito - round +25hp/ it`s that good idea ?? any tips where to find some kind of small set n2o/nx,nos,elb..etc/ to buy?
Old 11-30-2005, 11:27 AM
yeah i forgot to mention plugs!! keep a set of NGK 9's handy for when you wanna spray!! i put those in for when i race at the track, and i keep a set of NGK 11's for daily drive... the 9's reduce chances of detonation!!
also the guys down at the shop that builds my car have a used ZEX wet kit for sale... $400.00
[/font]
