Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-12-2005, 01:48 PM
sprtfn25 sprtfn25 is offline
turn signal malfunction
My 2001 Mitsubishi Eclipse RS' turn signals do not work. Click on the blinkers and nothing happens. Headlights,parking lights and hazards work perfectly. No indicator lights on the dash either when turn signals are used but do lightup when hazards are on. The turn signals worked before today but occasionally were blinking faster than normal. Any ideas out there?
Old 11-12-2005, 05:07 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Re: turn signal malfunction
First off, wrong forum, but no biggie!
Secondly, when you blinker flashes faster than normal, that means that a bulb is about to go out.
So replace some or even all of the bulbs. And I guarantee that, that should work. But if it doesnt, then try checking the fuse. It shouldnt be anyting major!
GL
