Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 11-12-2005, 12:01 PM
Vip09 Vip09 is offline
Send a message via AIM to Vip09
The bar has been raised - 466whp 1zz
Hey.. just thought I'd bring this over here from newcelica.org. MWR has once again came through for the Celica community.. a new benchmark for the 1zz-fe.
Originally Posted by monkeywrench
Well, we had some race gas and an MR2-S just sitting there- what did you expect?
I decided to have a little fun with our shop car since most of the tracks in this part of the country have closed. In the past I've only tuned on the dyno with pump gas (425whp max) because we never had a clutch that would hold more. We do now so I decided to add some C16 and see what she'd do.
At 30psi we saw 466whp. Not bad but the tuning at high boost is rough to say the least. I know there's more power to be had. Maybe I'll take another swipe at it. I'm happy for now. It's running well and I've actually driven it to work a couple of times this week. It's still extremely driveable and will scare the bujeezus out of you with the boost turned up. Unbelievably it still hooks up pretty well through 1st on the drag radials.
I was running reduced boost in the midrange to go easy on the clutch- it's heavy but still not heavy enough. During another pull earlier at about 28psi I was not cutting midrange boost and it made 394 ft-lb at the wheels. Dynapack does not correct torque so this would actually be 402 ft-lb corrected.
- Yes, it's a stock 1zz trans with a quaife. No, it hasn't broken yet despite our best efforts.
- Yes, it's the stock plastic intake manifold and it has not exploded yet.
- Yes, it's got its original girly little halfshafts.
- Yes, it's got the modified Toyota 2zz head gasket that we include with the big bore kits.
- Yes, it's still open deck. It won't be for next year though.
- Yes, I accidentally had the rev limiter set at 7400 on the last pull :thumbdown
- The Dynapack reads exactly the same as an honest Dynojet, for reference.
- Yes, that's really 535hp and 460 ft-lb at the crank
Matt @ Monkeywrench
http://www.monkeywrenchracing.com
2000 Celica GT-S 184whp NA / 275WHP with MWR turbo @ 7psi
2001 MR2-S turbo - 465 whp 1ZZ and climbing!
Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
Best Alltrac times: 1/4: 13.3 @ 102mph (older setup) 1/8th: 7.8 @ 83mph (old setup)
Old 11-12-2005, 02:09 PM
SigmaProjects's Avatar
SigmaProjects SigmaProjects is offline
Send a message via AIM to SigmaProjects
Re: The bar has been raised - 466whp 1zz
lol... 30 PSI?? wow that's a lot.
RAs, the last of the RWD Celicas... http://truestreets.com/ now out of BETA
Old 11-12-2005, 02:33 PM
91 Celica St 91 Celica St is offline
AF - Advisor
wow thats alot of boost for a 1zz, whats been done to it vip?
Old 11-12-2005, 09:34 PM
http://monkeywrenchracing.com/mwrmr2_s.html
Old 11-12-2005, 11:32 PM
AF - Advisor
thanks bro
