Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-12-2005, 07:55 AM
kahf's Avatar
kahf kahf is offline
Send a message via AIM to kahf Send a message via MSN to kahf Send a message via Yahoo to kahf
B16b HELP
HEy
Im getitng a B16B motor and im trynna swap wit with my stock JDM d16y6.
I've heard the hp rating for B16b is around 180 bhp
is it so?
also would the motor mount in easily?
secondly what about the ECU? im not sure if Im gettign an ecu with it? can Iuse my stock ecu?
also, im new ot all this, kindly xplain what is"OBD2a - OBD2b "
n if this is related to my case
thanks guys
Old 11-15-2005, 11:17 PM
Liquid Silver Liquid Silver is offline
Banned
Re: B16b HELP
They have 185 crank hp at 8,000rpm and 118 ft/lbs around 7,800rpm. vtec engages at 6,100rpm and fuel cut is at 8,400rpm.
You will have to use the ECU for a B16B, which should come with the swap if you get it from any half-reputable company/website. Remember the ECU on jdm cars is on our driver's side, so the entire wiring harness will need extended since it will be going on your passenger side. Pickup about 80 butt connectors, some 8,10, and 12 gauge wire, and get your splicers ready.
The motor will bolt right in to a 99-00 chassis, and I'm pretty sure the same goes for 92-95 also. Your swap should come with B16 motor mounts. If not, go to www.ha-sport.com and buy some.
I think the B16B is OBDIIa, not sure though. I know there is only one O2 sensor with this setup (it's on the exhaust manifold) and your second stock hole will need plugged.. or just leave the old sensor in there and cut the wires to it.
If your swap doesn't come with axles, the only replacements that will fit are one from a 99-00 Si with ABS. Yes I know your car doesn't have ABS brakes, but Civic Type R's do and non-abs shafts will be too short.
Let me know if you need anything else, the swap should be pretty easy.
