plz help my jimmy went crazy
ok,
all my gauges do not work and niether does my automatic transmission. i dont know what to do. the problems started to happen at the same times so i think its 1 connection or something like that. plz help me asap i need to get it working so i can get working ty. btw its a 93 Last edited by joshwelt; 11-12-2005 at 04:07 AM. |
Sounds like a ground issue. (Do you have the digital cluster?) I would start to pull all your engine/body grounds, clean them with a wirebrush and sandpaper (and connecting surface as well) and make sure they're tight. If that doesn't solve it, you probably have a live short somewhere between the firewall and the transmission (which can cause funky issues with your cluster because of info passed the the ecm via the drac...)
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
ok...????
am not to sure what u meen by cluster,( u meen the gauges? if so they are standard) but i guess i can try to find the grounds and clean them. im not a mechanily inclined person but thx for pionting me in a direction to fallow. |
Re: plz help my jimmy went crazy
Yeah, by cluster I meant gauges. (Gauge Cluster)
Did you check your fuseses? That will give you an idea if you have a short or not.
yeah i checked the fuses. none were broken but i replaced them all just to be sure.
