Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 11-11-2005, 09:39 PM
s2h0a0n6e s2h0a0n6e is offline
subwoofer enclosure
i just modded my stock sub enclosure in my 03 tib....and i put a 10 inch sony xplod 1100 watt sub in there and i have it all hooked up and everything but i think i need a bigger amp because its not hitting as hard as it should....or whats goin on......if i need an amp what would someone that knows what there talkin about reccommend
Thanks
Old 11-12-2005, 03:13 AM
free2roamaz free2roamaz is offline
Send a message via AIM to free2roamaz
What Amp and what's the numbers it puts out?
Old 11-12-2005, 12:19 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: subwoofer enclosure
dont power an afftermarket sub from your stock amp...
and check to see if youre giving enough air room for that particular sub....
ohh and do ou have an aftermarket headunit?>
almost that time
my sig made mommies cry, thats why i had to change it..
Old 11-12-2005, 12:41 PM
i am about to get a pioneer head unit.....and then i will hook that sub up to a small amp just for a little bit of bass.....what im askin is what is a good amp to power a sony xplod 10 inch 1100 watts
Old 11-12-2005, 02:10 PM
Rickna's Avatar
Rickna Rickna is offline
IS-F
Chances are there's not enough cft in the stock enclosure for a 10" sub. Many have tried...the results are mixed but leaning towards not enough air space.
Old 11-12-2005, 06:19 PM
BigTDawg BigTDawg is offline
Send a message via AIM to BigTDawg
you also want to get an amp with enough watts for the sub cause if you have an amp that doesnt have enough watts when you turn the volume up you'll burn out the driver cause you get distoration and it holds the cone in or out and there is no air moving to keep it cool and like wise if you have an amp that is too powerful you'll pull it out also so match the watts for both
