Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 11-11-2005, 07:37 PM
quilcene quilcene is offline
Temperature sensor
I need to replace thetemperature sensor onthe V6 1998 Mystique--
Where would that be located? The mechanic said it got fried when the serpentine belt went bad and the car was driven hot for an hour. Ithink it is on the topof the engine by the serpentinebelt somehwhere.
Old 11-12-2005, 09:44 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
which temperature sensor? intake temperature sensor, coolant temperature?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-22-2005, 10:28 AM
buchanan06 buchanan06 is offline
Re: Temperature sensor
Hello!
I have a 2000 Mercury Mystique 4-cyl. I just changed my intake temperature sensor Saturday. My check engine light came back on yesterday, so I took it for diagnostic scan. Code came up for Coolant sensor. Just an FYI, you may possibly have to replace both sensors!
Old 04-12-2007, 03:17 PM
dwovitt dwovitt is offline
I have a 99 mystique and was told to change the intake temp. sensor and can't find it on the car anywhere. Where did you find yours any help out there? please
Old 04-15-2007, 02:55 PM
pbrittain71 pbrittain71 is offline
I have a 1998 mystique v6 engine. Your sensor should be on the intake manifold if it is the intake sensor.
