Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-11-2005, 04:28 PM
TheRomer TheRomer is offline
Removing the BCS restrictor
on the web site dsmtuners.com it says to remove the restrictor in the waste gate selenoid. Im not really sure where this is but i have a clue. is it right near the exhasut manifold, and looks like a metal hockeypuck, or is that the wastegate? im not sure where the selenoid is, but once i find that, i know what to do from there.
also, has anyone ever done that and has any opinions or advice? it says it gives u 1-2 more psi. thanks
Old 11-11-2005, 05:34 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Removing the BCS restrictor
Removing the restriction on the boost controle silinoid will net you about 1-2psi. Removing the vac lines that run to it, then caping them and installing a MBC will net you as much as you want.
It is dirrectly under the Air box on the 2g.
DSM geek
Old 11-11-2005, 06:16 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
I suggest forgetting about the BCS resitrictor removal. Yes, it does net you 1-2 psi in more boost, but I had the hardest time in trying to take mine out. I never succeeded, and instead of fiddeling around with it and breaking the BCS, I just got a $40 JoeP manual boost controller and hooked it up in seconds. If your'e planning on running an MBC any time soon, I'd say just leave the BCS restrictor in place. Just my 2 cents.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 11-11-2005, 07:43 PM
I just put a wood screw in their and used a pair of pliers and pulled it out.
DSM geek
Old 11-11-2005, 08:16 PM
Shpyder's Avatar
Moderate moderator
Re: Re: Removing the BCS restrictor
I tried doing that, but the BCS was stuck in there so bad, it wouldnt even budge. The screw I used simply ate away the plastic of the restrictor!
Old 11-11-2005, 10:26 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I popped mine out with a wood screw also with no problem. But, I have another problem. I unhooked my lines from the BCS and put screws in them and put in a MBC. I try to adjust the boost and it never changes it. Do I need to cap the BCS also or what could it be?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-11-2005, 11:20 PM
I capped mt BCS. Sounds like you dont have the MBC installed correctly.
DSM geek
Old 11-12-2005, 03:54 AM
Well, thats what I thought, But I have the turbo xs bov. The bottom nipple goes to the wastegate and the side nipple goes to any vaccum line. Is this correct?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-12-2005, 01:41 PM
i think im gonna just get a MBC.. has anyone ever heard of Hallman ES Manual Boost Controller. Any opinions on this brand, or does anyone have a better brand?
Old 11-12-2005, 10:25 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Hallmans are way overpriced. I have heard lots of good things about JoeP mbc'c (www.joepmbc.com) and my friend Mike has one on the way. Hallmans are what like $100? JoeP's are $45 shipped, or you could get like $10 ones on eBay. Becareful though, those eBay ones have been known to shit out on people, however I have heard good things too.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
