Question on PCV Grommet
I'm getting 0171 and 0174 codes, mostly when my 99 is not warmed up. I started troubleshooting, and noticed the the PCV is not very snug in the grommet--it takes no effort to pull it out.
Should the PCV be snug in the grommet, and could this be causing my codes? Thanks. |
Re: Question on PCV Grommet
If the gromet is not snug to the PCV valve....you should replace it.
There is a lot of information on the codes you are getting at http://leckemby.net/windstar/windstar01.html |
Frostie... I had the same problem... wondering if it was snug enough. I asked a worker at Napa and he cut me a few inches of Fuel Line which made for a better fit. I don't know if it will still throw your codes though. Undahood
I had an issue with my groment with excess oil.. I now on every oil change pull my groment out and use dish detergent and clean it. Its still in good shape no cracks or dry rot so I did not replace it. After the cleaning everything is snug.. Hope this helps
I noticed my 2000 Windstar's PVC gromet was not hanging on to the PCV valve very well and my NAPA man had the replacement gromet instock for less than a dollar US as I remember.
It is cheap and easy to replace it. Jim |
thats not the codes .. its a fuel issue
