Old 11-11-2005, 02:44 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
Exclamation fuel pump wont stop!
alright, you know when you first turn the key to the "on" position, you hear the fuel pump going for about 2-3 seconds and then stops. BUT, when I turn the key, the fuel pump doesnt stop.. it keeps going and going and now it takes about 3-5 cranks to start up the engine when before it would fire up on the frist crank.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 11-11-2005, 02:56 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: fuel pump wont stop!
you're fucked. haha
no really, maybe try replacing the relay and then see if it still does it. if the problem is the actual pump you might have to drop the tank again...didn't you just replace it? i know i did....lotsa fun.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 11-11-2005, 03:40 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
My guess would be that the pump isn't able to build up pressure to prime the system. Not sure what exactly the reason could be. I just had to drop the tank on my winter beater for the same thing and found out that one of the fuel lines close to the pump was leaking so I had to replace the whole damn pump.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 11-11-2005, 03:44 PM
yeah man i just replaced it.. it was a pain = ( it has a brand new pump in it..
Old 11-11-2005, 05:01 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Re: fuel pump wont stop!
Originally Posted by SG007
you're fucked. haha
Oh yeah that was big time fun, I had to do it too. Well I also think its the relay.. doesnt cost much either.
Old 11-11-2005, 05:30 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Yeah, relay sounds right. But does your oil pressure gauge work right? The fuel pump runs as soon as it sees oil pressure. If you loose oil pressure, the car will die.... comforting......
Old 11-12-2005, 09:43 AM
yuuup.. my oil pressure gauge works fine. The fuel pump relay is on the passenger or drivers side in the engine bay?
Old 11-12-2005, 10:20 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
driver side
Old 11-14-2005, 09:22 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
What's the progress on this, I'm curious.
Old 11-14-2005, 01:04 PM
ive been slacking off lately and ive been driving my daily driver (POS corolla). I got a new TPS and a new IAC but have yet to install them. My check engine light came on today when I turned my car on.. ill pull the code. Havent checked the fuel pump relay yet. i dont have time =(
Old 11-14-2005, 03:47 PM
wrightz28's Avatar
IS yours a MAF or Speed density system?
Old 11-15-2005, 12:47 AM
speed density
Old 11-15-2005, 03:14 PM
kahjdh's Avatar
kahjdh kahjdh is offline
That car hates you
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-15-2005, 03:31 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
i highly doubt the bad relay... if that was bad it wouldn't turn on. uness for some odd reason it's not sending the right amount of voltage... but this is probably not likely. just like CamarosRsweet said, the pump continues to run until it has built up sufficient pressure, the fact that it is taking longer means there is a pressure leak somewhere or the pump is defective. lack of pressure is why your car takes longer to start.
is gas cap installed correctly and holding pressure?
leaking fuel anywhere?
reset computer.
exchange fuel pump (I know... it sucks)
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 11-15-2005, 03:51 PM
wrightz28's Avatar
this is the part where I'd start thinking about buying an external pump.
