Old 11-11-2005, 02:08 PM
UncaringMrBC UncaringMrBC is offline
blow off sitting still?
how do i blow off sitting still...i have an "open to atmosphere" bov but when i am sitting still with the clutch in or im in neutral i can rev my engine up to red line and it wont make a sound when i let off from the bov....i noticed when i was taking off on a hill once i had the clutch out alittle ways and was reving it up and it would blow off loud when i let off of the gas....is there a reason that it doesnt blow off when im just sitting still and reving?
Old 11-11-2005, 02:16 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Re: blow off sitting still?
Boost pressure usually starts to build when you are wide open throttle. I don't think you can build enough boost pressure to hear blow off by the time you hit the red line. If you were to hold the pedal down to the floor and let pressure build while bouncing off the rev limiter, I'll bet your BOV will make a sound but I HIGHLY recommend you don't do this. It's not worth blowing an engine to get your BOV to sound.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 11-11-2005, 03:15 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Well I have a greddy type s bov that is recirculated and I can do that in neutral or with the clutch in. I only have to rev it too about 5k or so. Although when I had the stock bov it would not do it; at least loud enough to hear it.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 11-11-2005, 04:32 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
it depends on the bov's spring pressure, also...when you are accelerating, you're putting a load on the motor, which builds boost. you can not build boost by sitting in neutral and revving.
Old 11-11-2005, 06:16 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Uhhh, I hate to burst your bubble but I can build boost when I rev my motor sitting still. lol I can hear my BOV also and I only rev it to about 4500rpm... Then again, I am running my t25 and stock BOV still. lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-11-2005, 07:03 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
The T25 can usually blow off in neutral, but only 1 or 2psi max
bigger turbos build even less pressure.
There has to be load on the motor to make significant boost
now - 2000 civic
soon - 2002 is300
Old 11-11-2005, 07:55 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Re: blow off sitting still?
Correct, unless you have a studder box.
DSM geek
Old 11-11-2005, 10:41 PM
on the T-25 you'd be lucky to see 1-2 psi in neutral just like crunchymilk said. also on the T-25, when revving it in neutral the bov is louder compared to doing the same thing with say a 16g, etc. besides revving your car to 5k all the time in neutral is a waste just to impress people...then you get those other people that are like "what the fuck is wrong with that dudes car". although, i did it all the time when i first got my ssq i still love driving though the tunnels in pittsburgh, building boost and letting off, hehe...
Old 11-12-2005, 04:02 AM
Nothing tops a good blowoff in a tunnel! lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-12-2005, 04:24 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Isn't this the 2nd thread on this in like a month? I don't understand why you cant build boost with the clutch in either though.
But *why* do you have to have a load to build boost? Aren't the same amount of exhaust gases leaving at 3k rpm with the driveline separated and at 3k rpm with it connected?
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 11-12-2005, 02:26 PM
You are able to build boost, but because of no resistance (clutch engaged to tranny, to wheels, to ground) the motor revs too quick and it doesn't have enough time to get the turbine spinning enough to build boost. That is why with a small turbo like my t25, the turbine is lighter and it can actually get spinning a little to build some boost before your motor can't rev any higher. Thus, resulting in the BOV having some pressure to release. Whereas larger turbos like 20g's have heavier turbines and doesn't have enough time to spin barely at all before you can't rev any higher... I think I explained that correctly... lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-12-2005, 06:23 PM
Re: Re: Re: blow off sitting still?
Sort of, but think of it this way, what takes more energy? Running in place? or running?
When the engine has to "pull" something, it has to work harder. This is why when you floor it in neutral you fly right to redline, but if you do it in gear, you won't just fly to redline, because you're pulling something, the car heh.
This working harder = building boost
now - 2000 civic
soon - 2002 is300
Old 11-12-2005, 07:30 PM
Nayr747's Avatar
Ok well I understand that it takes more work to do something when there is a greater load but I'm just confused how exactly that works in an engine. Are there more exaust gases leaving under load? Because if you measured the hp with no load wouldn't it be almost nothing?
Well what if you didn't floor it but just reved it to 5k and held it for a couple seconds then let off? And what about highly modded cars that go through the powerband as quickly as we do in neutral. And they have incredibly laggy turbos.
Old 11-12-2005, 08:22 PM
It will build just as much boost as it can if you bounce it off the rev limiter. Once again, we are back to the whole resistance theory...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-13-2005, 11:31 PM
bryan_bigd's Avatar
bryan_bigd bryan_bigd is offline
if i were you i would check and see if you have any leaks going from the engine to the turbo. if not then you can rev your engine one time to 4500rpms and the again to 5000 and the again to 6000 and the turbo wheel should have started to spin and the vacume pressure should be strong enough to close the waste gate door and it should make a nice blow off sound.
on my 91 eclipse i rev 14 pounds of boost in nutral and it blows off nice into the air,
on my 95 tsi with the 16g it can rev 12 pounds of boost in nutral and it is still realised throw the intake and it sounds good
1995 talon tsi 10-26lbs of boost boost controller k&n intake 550cc injectors 255 fuel pump ported head 3 angle valve job hks metal head gasket arp head studs racing manifold evo3 16g ported turbo 34mm wastegate 3in turbo back exhaust no cat act 2600 clutch 7.9 lbs fly aem 9.3 plug wires irradom plugs lowered 2 in camber correction all four wheels 2 3/4in upper intercooler pipe greddy rs BOV racing hard intake pipe apexi NEO fuel manigment system oh and it has the 6bolt motor
