Old 11-11-2005, 01:25 PM
elsolo elsolo is offline
washer pump electrical
1997 lesabre
Windshield washer pump does not work.
The pump is OK, it works if I run a test wire with +12 to it.
I cannot find a fuse or relay for the pump, is there one? The wipers work fine.
I am thinking perhaps the switch (for the washer pump) on the turn sinal lever is bad, anybody know which wire(s) to test?
Old 11-11-2005, 08:45 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: washer pump electrical
The wiper/washer is on the same fuse. It should be #25 in your fuse panel under the drivers side dash. It is a 25 amp fuse. If the wiper is working, I would say it is not the fuse and you need to check the wiring to the washer motor. The problem is more than likely in the lever switch. Check Ebay, you can find a new switch lever assembly for around $30.00 there.
