Old 11-11-2005, 12:48 PM
ulremember ulremember is offline
95 Camaro idling prob.
Hello to all.
I am working on a 95 Camaro with a 3.4 ci motor. The problem is that after driving for a while, the idle increases to about 2000 - 2500 r's. If we turn the ignition off and restart, the idle holds for "a while", then goes back up.
Had codes pulled. Replaced the EGR valve and the idle compensating valve/solenoid. The problem is still there. I was wondering if it could be the computer not sending the correct voltage to the ICV. Some one said to oil the shaft of the valve. I used the ol' wd-40. no improvement.
Have found no other codes as of yet. Any suggestions are appreciated!
Thank you in advance.
Chuckster
Old 11-11-2005, 03:43 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: 95 Camaro idling prob.
Just a guess but I would say that the problem is that you have a 3.4 ci motor in it when you should have a 3.4L (207 ci). J/K
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 11-11-2005, 03:57 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
vacuum leak?
