Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 11-11-2005, 12:42 PM
bcopeland bcopeland is offline
Cold Passenger Air
I talked to the dealer several times about the col;d air on the passenger side and they continue to believe it is an AC problem. Anybody experience this>
Old 01-11-2006, 09:30 PM
DBW DBW is offline
Re: Cold Passenger Air
I have the same problem. At 70 mph, there is enough wind coming into the cab, above the heater ducts, but just below the glove box to blow out a match. Living in Michigan, this means the heat is always on too hot for the driver, and the passernger needs a blanket. Mechanics cant find anything.. .help, we're freezing our a_ _ es off in our $50,000 luxury vehicle!!
Old 01-28-2006, 11:48 PM
Jeepin_CJ7 Jeepin_CJ7 is offline
I'm having the same problem. I am going to try to tackle it this summer according to the TSB listed below (sounds like fun).
BTW...A search for "cold passenger air" gave me the thread on this. I had found the thread this past fall, but never got around to fixing it.
Heating, A/C - Passenger Side of Vehicle Colder/Warmer
File In Section: 01 - HVAC
Bulletin No.: 01-01-37-008
Date: April, 2001
TECHNICAL
Subject:
Passenger Side of Vehicle Colder/Warmer Than Driver's Side
(Repair HVAC Case to Cowl Seal)
Models:
1999-2001 Chevrolet and GMC C/K Pickup (Silverado, Sierra) and Utility (Suburban, Tahoe, Yukon, Yukon XL) Models
2002 Cadillac Escalade
Condition
Some customers may comment that the passenger side of the vehicle may be:
1. Colder than the driver's side when the heat mode is on.
2. Warmer than the driver's side when the air conditioning (A/C) mode is on.
3. There may be dampness on the vehicle dash assembly when the A/C mode is on.
Cause
Condition may be due to poor sealing of the HVAC air inlet case to the front of dash or the recirculation mode door actuator may not hold the recirculation door closed while driving.
Correction
Replace the recirculation door actuator (if necessary) and repair the HVAC case to cowl seal using the following procedures:
1. Place the A/C control in the manual heat mode.
2. Remove the fixed mast radio antenna.
3. Open the hood and install fender covers.
4. Remove both wiper arm assemblies using the following procedure:
4.1. Disconnect the washer solvent hose from the air inlet grille panel nozzle.
4.2. Remove the cover from the wiper arm retainer. Remove the retainer.
Important: Use a battery terminal puller in order to remove the wiper arm.
Rock the wiper arm back and forth in order to loosen the arm from the drive shaft. Remove the wiper arm.
5. Lower the hood.
6. Remove the air inlet grille panel using the following procedure:
6.1. On each end of the air inlet grille panel is a rubber flap for the hood hinge cutout. Lift this flap and remove the air inlet grille panel attaching screw.
6.2. Remove the air inlet grille panel center top push pin.
6.3. Remove the clips that position the forward edge of the grille panel to the top of the cowl.
6.4. Disconnect the windshield washer supply hose from the bottom of the grille panel.
6.5. Remove the air inlet grille panel by sliding the panel rearward up the windshield and out.
7. Just to the left of the right hood hinge, on the horizontal surface of the cowl, locate a cover that is sealed in place. The cover has TRW stamped into it.
8. With a sharp knife, cut out the panel following the panel impression in the sealer tape.
9. Place a lifting device between the cover and the dash. Lift the cover enough to allow another tool to depress and release the front retaining tabs by pushing rearward on them. Remove the cover.
10. Look through the opening where you just removed the cover. You will see what looks like a piece of foam about 76 x 127 mm (3 x 5 in). This is the A/C recirculation door that is within the HVAC module.
11. Reach into the opening and carefully pull on the air inlet recirculation door. If the recirculation door moves with very little effort, replace the air inlet (recirculation) door actuator (Manual systems only). For systems with the Automatic Temperature control, initialize the system using published Service procedures.
12. Between the top of the HVAC air inlet module (appears as a 6 mm (1/4 inch) black strip) and the cowl sheet metal is a foam seal. This foam seal may be improperly positioned or damaged in some way (insufficient crush/sealing). This may allow outside ambient air to enter the passenger compartment incorrectly (under driving conditions). This can be corrected using the following procedure:
Important: It is imperative that a good seal be achieved over the entire surface areas (no voids or skips), especially around the rear and sides of the HVAC case to cowl areas.
12.1. Seal the area between the cowl and HVAC case with RTV Silicone Rubber Sealant, P/N 12345739 (in Canada, use P/N 10953541).
12.2. Using your finger, from the engine side of the cowl, ensure that the foam is stuck nicely to the HVAC module and does not have any distortions.
12.3. From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, place a shop cloth into the opening and cover the blower fan. This keeps silicone from dripping onto the motor and causing an imbalance condition.
12.4. From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, apply the RTV silicone to bridge the gap and cover the foam between the cowl sheet metal and the HVAC module case. Inspect your work with a light and a mirror. Ensure that no gaps or skips are present in the RTV seal.
12.5. Inspect your work for potential drips, runs, etc. If no problem is seen, remove the shop cloth covering the blower motor.
13. Apply a 3 mm (1/8 in) bead of weatherstrip adhesive, P/N 12345097 (in Canada, use P/N 10953479) around the opening in the horizontal surface of the cowl, where the cover fits into the cowl.
14. Place the cover on the workbench, top on the surface, and apply a 3 mm (1/8 in) bead of weatherstrip adhesive on the edge of the cover.
15. Place the cover into the cowl opening and snap into place.
16. Apply another bead of weatherstrip adhesive around the joint between the cover and the top of the cowl. Smooth this bead into a smooth surface with a finger or tool of some kind.
17. Place the leaf screen to the cowl. Attach the washer supply hose to the bottom of the air inlet grille panel. Do not place the fasteners in at this time.
18. Install the radio fixed mast antenna. Tighten 1/4 turn after contact is made with the base.
19. Lower but do not close the hood.
20. Center the opening in the air inlet grille panel around the antenna mast and then install the air inlet grille panel retaining screws.
Tighten
Tighten the screws to 2 Nm (18 lb in).
21. Raise the hood.
22. Reinstall the air inlet grille panel center retainer and front edge retaining clips.
23. Cycle the wipers to ensure the wiper system is in the parked position.
Important: Inspect the windshield lower edge on each side. About 51-76 mm (2-3 in) from the bottom, you will find a 13 mm (1/2 in) long black mark embedded in the glass. The black line is the position for the wiper blade to be in when the wiper system is in the parked position.
24. Install the wiper arm assemblies. Position the wiper blades just below the black marks in the windshield.
25. Install the retaining nuts.
Tighten
Tighten the retainers to 25 Nm (18 lb ft).
26. Reconnect the washer hoses.
27. Remove the fender covers.
28. Close the hood.
Old 01-29-2006, 05:20 PM
DBW DBW is offline
Thanks for the reply. Looks like way too much for me... and unfortunately, sounds too complicated / costly for the competance level of the dealers in my area... so will have to think about this...Maybe sell it and buy a Ford or Lexus?
Old 01-29-2006, 10:56 PM
A guy on the delphi GM SUV forums had it fixed at his dealership. He states below what was done. He also stated that he had used expanding foam that was holding up well, before he took it to the dealer.
Brad:
The mechanic went into the area in front of the windshield
and directly below the wipers. I think he removed the wipers
and the cover under the wipers. I did not watch him do the work.
All the repair work was done from the outside. He had done
the job before and knew exactly what to do.
The information I have from the work order is:
Line 1 Inspect and repair for cold air coming in under the
passenger side of the dash. Cause: not sealing off properly.
Repair: Resealed HVAC case to cowl seal, Bullt. 01. 01 37 008
OPCODE: 0100 Hrs. 1.7 $83.30 plus tax.
The recirculation door actuator was ok. (The service bulletin
covered this item as well as the lack of a good seal.) The lack
of a good seal is the main problem, not the door.
I know he hit one open area or more because when I got into the
vehicle I could smell the silicon odor inside the vehicle; the
windows had been left up. The odor is gradually fading.
Orville
