Old 11-11-2005, 01:26 PM
the.dude's Avatar
the.dude the.dude is offline
blower problems
I finally decided to replace my blower because I'm tired of the squeal for the first five minutes of every trip. I bought a 'unimotor' that came with the cage, and plug. I was suprised how similiar it was to the old one.
When I put it in, the thing runs for about 3 seconds then stops, after about 5 seconds, it runs for 3 more seconds. Then its dead till I shut off the system and restart.
I have a 98 gtp, climate controlled. We tried 3 different blowers at the parts store and checked the plug with a test light. The old blower still works when you plug it in, and the test light showed continuous power.
HELP
Old 11-11-2005, 01:33 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: blower problems
The blower motor for the climate control A/C is different from the one for manual A/C. First make sure that the parts store sold you the correct one. AC-Delco part number for the climate control is 15-8950, the one for manual controls is 15-8949 and they are not interchangeable.
Old 11-11-2005, 02:23 PM
the.dude's Avatar
Re: blower problems
Thanks a ton for the info. The parts guy at the dealer gave me two numbers
52489322
52489321
gmpartsdirect shows them both for the 97-00 GP
which one do I need?
Old 11-11-2005, 03:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: blower problems
52489322
52489321
322 is blower motor for auto ditgital temp. control
321 is blower motor for the manual HVAC
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 11-11-2005, 03:24 PM
richtazz's Avatar
Re: blower problems
you need the 52489322 (Delco #15-8950). Be careful on gmpartsdirect, they charge a ton for shipping, and it almost ends up costing you as much as just getting it at the dealer. The Delco part comes with a new silencer panel, as they usually crack and break when you try to remove them.
