Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-11-2005, 12:09 PM
larrybir24 larrybir24 is offline
Question 1970 Nova Floor Replacement
Im replaceing the floor in my nova and i wasnt sure what the best way to weld in the new floor is? Do i drill holes and spot eld it like it came or do i run beads on the new floor pans. Also how do i get the under neath of the car to look good because im overlapping the floor pans to be able to weld them better.
Old 11-22-2005, 05:19 PM
70Nova05 70Nova05 is offline
Re: 1970 Nova Floor Replacement
I would spot weld it in place first, just to make sure it is square before welding it down completely. Keep in mind with 2 subframes, Nova's get their strength from the driveline tunnel as a structure curve, so weld carefully and well.
Old 07-05-2007, 02:03 PM
73 restorer 73 restorer is offline
In the shop i work in we always weld the panels all the way around. we only butt weld the panels due to fact that if overlap you will have rust in between the overlap you cannot see. which ever way you weld is your choice but when you grind the welds, go to the body shop and by some 3M seam sealer you can buy in a can and use a nice paint brush to apply it. You can san it smooth and make it look like no work has been done.
Old 07-05-2007, 02:04 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
This is your 13th post you resurrected...and you only joined today!!! That must be a new record.
Thread closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
