Old 11-11-2005, 10:28 AM
tomany tomany is offline
cam shaft sensor replacement
i am trying to replace the cam shaft sensor on my 98 lumina 3.1 due to a code saying it is bad. i cant get it out due to lack of room pulling it straight up as it hits the power steering resorvoir....is there a way to get it out without having to pull the whole power steering pump...im not a mechanic, but i try ....
Old 11-11-2005, 03:38 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: cam shaft sensor replacement
No big deal to remove the pump, just a couple of bolts. Don't need to take the lines off or anything, just unbolt it and tip the whole thing out far enough to clear your sensor.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-11-2005, 03:44 PM
PS, take the belt off so you can turn the pulley, you have to access the bolts through the holes in the pulley...
...empty gun rack.
Old 11-11-2005, 03:48 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
There is a plastic clip that holds the power steering lines out of trouble on the back of the motor. Pop the lines out of that clip to give you a little more flexibility in moving the pump out of the way.
Old 11-11-2005, 07:57 PM
many thanks guys for your response...tomany
