Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 11-11-2005, 11:11 AM
toddluck toddluck is offline
Question 93 voyager crank sensor?
i have a 93 voyager 3.o it quit running all of a sudden!
it has no spark...new coil installed still no spark checked all the fusable links and fuses and also any relays i could find all are ok... does the 3.o have a crank sensor? and where is it located ...any help would be much appriciated..thanks
Old 11-11-2005, 11:32 AM
Re: 93 voyager crank sensor?
ill check back
Old 11-11-2005, 11:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
It is In the dist..
Have you got any codes?
MT
Old 11-11-2005, 11:36 AM
Re: Re: 93 voyager crank sensor?
im not sure how to retreive the codes on this vehicle it belongs to my sister im just trying to get it going for her
Originally Posted by MT-2500
It is In the dist..
MT
Old 11-11-2005, 11:54 AM
i get a code 11 no power to ignition
Old 11-11-2005, 12:20 PM
MT-2500's Avatar
AF - Advisor
Code 11 is no crankshaft ref signal during cranking.
If your parts place can check dist have the test it.
MT
Old 11-11-2005, 02:23 PM
ok i guess i need to start over here...are there any relays or fuses that may be hidden ...that operate the ign system????...i have installed a new coil and distributor today and still nothing!!
Old 11-11-2005, 03:01 PM
MT-2500's Avatar
AF - Advisor
Check for 8 volt power to crank sensor with key on.
Also remove dist cap and see it the dist rotor is turning.
If your timming belt is broke the dist will not turn.
MT
Old 11-11-2005, 04:50 PM
thanks for all your help it has a snapped timing belt..again thanks for everything
Old 11-11-2005, 05:01 PM
MT-2500's Avatar
AF - Advisor
You are welcome. I was afraid of that.
At least you found the problem.
MT
Old 12-01-2005, 11:15 AM
xxxtazmanxxxx xxxtazmanxxxx is offline
Toddluck....DO I know you from say ANOTHER forum?
