Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-11-2005, 10:08 AM
cj hupp cj hupp is offline
95 yj wont start
it started a few months ago being hard to start but it would always fire up eventually. About 2 weeks ago it stalled on me on the wey to work and couldnt get it started back up,so I had to be towed home 43 miles.After I was home I tried starting it again but no luck. For some unknown reason I had left the key in the on position. after a couple of minutes the fuel pump relay and auto shut down relay started clicking,then I had fuel presure and was able to start up. I changed the fuel filter, ignition switch ,coil ,and plugs and wires. I droped the fuel tank thinking i may have a fallty fuel pump,but it works when I run 12v to it. Any suggestion would be awsome. c.j.
Old 11-11-2005, 02:20 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I had a very similar problem. Turned out to be the fuel pump relay. There was small crack on the side of the relay. I did replace the ecu and cps before replacing the relay. Hasn't had the issue since, except when off roading and the relay wiggles loose.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 11-11-2005, 11:17 PM
Re: 95 yj wont start
THANKS FOR THE INFO I'LLGET ONE IN THE MORNING AND SEE IF IT WORKS
Old 11-12-2005, 08:11 PM
Re: Re: 95 yj wont start
I REPLACED THE RELAY AND NO LUCK. THE RELAYS CLICKED AGAIN AND I WAS ABLE TO START THE ENGINE. I DROVE FOR A FEW MILES AND STALLED OUT. IT'S LIKE WHEN EVER THE ENGINE GETS GOOD AND WARM I LOOSE SPARK AND POWER TO THE FUEL PUMP.RRRR. WELL BACK TO WORK.
Old 11-13-2005, 06:45 PM
ufatbasted ufatbasted is offline
Could be the fuel pump ground that attaches to the mounting bracket for your e brake. I had a similar stalling starting problem and that was and still is my problem as I cant find the damn wire.On my rig if the fuel gauge pegs to full when I turn the key it wont start. Watch your guage when you have trouble starting. If it pegs to full you may have the same problem as me. I'm able get started buy pulling the ebrake release lever a couple times.
Old 11-15-2005, 12:06 AM
Thanks for the info. Im going to try it out this weekend. I had my brother pull my jeep to my dads house since he has a garage and I don't. I hait working on vehicles out in the bad weather.Thanks again and i'll get back to you on this.
Old 11-17-2005, 11:25 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
You may want to check out the battery cables. I had a vehicle that acted the same, I found corrosion in the positive cable, under the insulation, about 6-8" away from the battery. Replaced the cable and no further probs.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-25-2006, 12:06 AM
sorry it took so long to reply. about 4 months ago I was able to get it running. It turned out to be the computer.What made me realize that was the check engine light wouldnt even light up.So I found a computer out of a 91 yj on ebay and she fired right up and have been driving it ever since runs great.THANKS ALOT FOR EVERYONES HELP. OIIIIIO KEEP JEEPIN
