Old 11-11-2005, 12:23 AM
95cutty 95cutty is offline
Send a message via AIM to 95cutty
rough 1st to 2nd
i have a 96 blazer with the 4.3 which has decided it doesnt want to shift from 1st to 2nd. the only way i can get it to shift is to run the rpms up to 4000 then back off and it will shift, but hard. i dont know anything about transmissions and it just started doing it and i havent had time to take it somewhere. does it just need serviced or a new filter or what? someone tell me something
Old 11-11-2005, 03:37 AM
Rick1488 Rick1488 is offline
Re: rough 1st to 2nd
I don't think changing the fluid and filter is going to fix your problem. I think it's much more severe and is going to need some trans work done on it immediately....
Old 11-11-2005, 10:41 AM
jsgold jsgold is offline
Get it to a transmission shop ASAP. Might be lucky and be a reasonable repair, ie, modulator or valve body, but let an expert fix this for you. They should be able to diagnose it and give an estimate.
I used to be indecisive, now I am not so sure.
Old 11-11-2005, 04:30 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
might just be a 1-2 shift solenoid.
Check it out sooner than later.
Not having it checked out will have you replacing the tranny instead of a 20 dollar valve.
1995 Factory Blazer Service Manual for sale, PM if interested.
