Old 11-10-2005, 10:09 PM
paulfischer paulfischer is offline
EGR Insuf Flow
hello all,
lately i have been the EGR insufficient flow code. I've cleaned the egr valve, tubes and all. reset code with scanner. Fine for a few weeks, than code comes back. Is the egr valve going?? or another issue here?
99 3.8 LTZ sedan 130,000 miles
Thanks Paul
Old 11-11-2005, 11:28 AM
maxwedge maxwedge is offline
A990 racer
Re: EGR Insuf Flow
A bi-diectional scanner can commnad the egr on to confirm operation, this would normally stall the engine, starting point here. Has any work been done around the engine recently?
Old 11-11-2005, 03:44 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: EGR Insuf Flow
Check your PCV valve housing. There is a spring and two o-rings, one on top and one on bottom. IF the spring is broken or missing, or one of the o-rings are missing or torn, the resulting vacuum leak will cause an Insufficient EGR code to trip. The MAP sensor sits on top of the PCV housing, and the PCM uses MAP sensor signal to monitor EGR efficiency. GM makes a repair kit, part #89017274 that consists of the PCV valve, spring, both o-rings and the top piece that the MAP snaps into. It costs $20 from a dealer.
Old 11-11-2005, 06:31 PM
A990 racer
Thumbs up Re: EGR Insuf Flow
Rich, that's why I asked if any work was done, you type faster than I do, figured I'd let him tell me the manifold or pcv was replaced
Old 11-12-2005, 01:03 PM
no work has been on the engine recently. will check the pcv stuff out.
Thanks!!! greaty appreciated.!!
Paul
Old 11-18-2005, 03:39 PM
Got the kit, and installed it today. The old o rings seemed worn. The car seems to run a bit better. Reset the light, so we shall see what happens.
If the pvc vale assembly was leaking air, would it cause the car to act weird or affect performance??
Old 11-19-2005, 09:19 AM
richtazz's Avatar
Re: EGR Insuf Flow
yes it would, because the MAP sensor is located just above it and will get a funky reading if the PCV is mucked up or there is a vacuum leak around it. hey Max, I've answered that question so many times, I now have the response saved so I can just copy and paste.
Old 11-22-2005, 10:46 AM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Re: EGR Insuf Flow
Originally Posted by paulfischer
hello all,
Thanks Paul
Hehe....I've got the exact same car with the exact same mileage (more or less) and exact same engine and exact same problem. I swapped the valve with a junkyard one. Make sure to use a new gasket. And clean all electrical connections and sensors in the throttle body with electrical cleaner. My problem went away.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
