Old 11-10-2005, 11:07 PM
GTP SUPERCHARGED GTP SUPERCHARGED is offline
Send a message via AIM to GTP SUPERCHARGED Send a message via MSN to GTP SUPERCHARGED
tune up
guys im doing a tune up on my 98 GTP, what all should i do??
Old 11-10-2005, 11:25 PM
mobil_12 mobil_12 is offline
plugs, wires, pcv valve, air filter, and fuel filter. I believe that your car takes platinum spark plugs, ask your parts place for O.E. fit plugs. Also check your owners manual for scheduled service for your mileage. You might need fluid changes as well.
"The Constitution shall never be construed...to prevent the people of the United States who are peaceable citizens from keeping their own arms."
-Samuel Adams, 1786
Old 11-11-2005, 11:12 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: tune up
Is your GTP stock or do you have any mods? How many miles on it?
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 11-11-2005, 07:40 PM
Re: tune up
its stock as of right now, its got 106,00 miles
Old 11-11-2005, 07:50 PM
BNaylor's Avatar
Re: Re: tune up
Since you're stock I'd recommend going with the AC Delco 7mm silicone plug wires. For spark plugs, either the OEM AC Delco Platinums or AC Delco 41-101 Iridiums. If you haven't done so, don't forget to drain and replace the supercharger oil. Good luck!
Timeslip 08/12/06
Old 11-11-2005, 08:21 PM
Re: tune up
how difficult is it to change the supercharger oil, and how do i do it?
Old 11-11-2005, 08:27 PM
BNaylor's Avatar
Re: Re: tune up
You'll need 2 bottles of GM supercharger oil. The stuff smells very rancid and don't get any on you. Here's the procedure most us use below:
http://www.clubgp.com/cgi-asp/mods.asp?modid=13
Timeslip 08/12/06
