I need your TQ
i asked this question over at thirdgen.org and i almost got shot
..oh well .. if you have the stock 10 bolt rear.end that is STOCK please answerif you have a third gen what kind of TQ are you making??..i can take estimated #'s What kind of abuse are you giving it?? auto or manual tranny? any problems with the rear end?? thanks John
1984 Camaro 5.7L 350 700R4 Holley 650 Cfm Edelbrock Performer Intake-Manifold Crane Cams Duration @ .050": 204/214 Lift:420/442 Summit HEI Distributor Hedman Shorty Headers Hedman Y-pipe Dynomax Turbo cat-back NOS Decal VTEC Decal |
Re: I need your TQ
dont know about numbers but ive heard about ppl running stock 10 bolts into the 10's...ya i was shocked...it all depends on the rearend some are different then others even though they are the same...does that make sense....the only true way to find out if it will hold is to push it till is brakes...
1991 RS 305 T.B.I. 700-R4
You gotta pray that while god was busy forging LS1s he had time to do your 10 bolt as well.
-Tony- Sold my Z28 looong ago. Now sporting an '03 TJ.
I'm running a "stock" rear in mine...A stock Auburn unit, the stock Saginaw unit that came with the car shelled out at 35k with the little 305 in front of it. The Auburn's were the factory replacement for the Saginaws, which were far too weak for the stock 305.
Right now I am putting out 417 ft/lbs of torque at the crank, through a highly modified 700R4. I don't abuse it and I don't baby it either. Oh, and the 3rd gen boards are full of very immature children that think they know everythng about everything...Just ask them, they'll tell you so. |
ok thanks...i would rather not push it till it breaks....but i may be able to get ahold of a iroc posi..which will hold up better than the saginaw one....the lead guitarist in my band offered to sell me his 1986 Berlinetta v8..he swapped in the iroc posi rear........thanks for your help
Re: I need your TQ
band huh, got any audio samples?
mope sorry..not on the computer...im the drummer..we play 70's-80's rock.we call ourselves "Phoenix Rising"
Re: I need your TQ
Re: I need your TQ
4th gen rears are auburn I do believe....
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
Re: I need your TQ
Stock rear end on my T/A. LS1 4th gen.
Was making about 325 ft/pounds at my altitude. Rear end is still in one piece. Not many miles on it though. 29,200. When it finally is driveable again the rear will be getting new fluids.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
Re: Re: I need your TQ
Re: Re: Re: I need your TQ
yeah i know..what i was saying up there ^ was the guy swapped a open diff for a limited slip one....i just said it wrong and i was correcting myself....i want the limited slip differential (LSD)
Re: I need your TQ
4th Gens can be pretty much anything depends on gears/engine/year. Generally 93-97 Posi's are auburn and 98-02 are Torsen.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Re: I need your TQ
most power i would put through a stock 10 bolt rear end would be about 400hp, i know the torsen units regularly break at bout 450hp. as far as torque, im not 100% sure, but i have heard of them running 10's before. the secret is to set them up right, and stage them right, so that you dont slam the pinion teeth against the ring teeth and chip something. you have to load them to they are already touching and then pour the power on, they tend to live longer that way.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
