Old 11-10-2005, 07:42 PM
childersmark childersmark is offline
Heat always on after heater core replaced
I just replaced the heater core on my 98 blazer. When I put the dash back in, my heat adjustment doesn't work. I hope I don't have to remove the dash again. It stays on hot all the time. A/C compressors runs, but comes out hot. Any help is appreciated.
Old 11-10-2005, 11:44 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Heat always on after heater core replaced
vaccume, flat pack moter, or calble driven blend door?? my guess vaccume, and my guess, you forgot to/accidently bumped the vaccume line off of the blend door actuator
Old 11-11-2005, 05:12 PM
I think the blend door is electric. There are both vacuum diaphrams and electrical connectors. However, I think the blend door is electric.
Old 11-11-2005, 10:10 PM
S10Husky S10Husky is offline
You might have installed a screw in the wrong place. The bolt thats on the engine-side through the blower resistor hole must be used only on that location. If a longer bolt is used it will interfere with mode door functions.
Old 11-13-2005, 08:27 PM
Oh goodness, I hope it's not the wrong bolt. I would rather take a beating than to replace that thing again! Any idea how to test without removing or a better tool for removing other than an extension and universal?
Old 11-13-2005, 11:33 PM
extention and a swivel
Old 11-14-2005, 01:59 PM
The only option I think you have is to back out the bolt almost all the way out and then see if hot air is still coming out the vents.
