93 6cyl 3.3 clunking eng noise
My car has 84000 mi. At 80,000 the dealership diag. the following and repairs for $2600. $2100 of that was labor:Water in eng.oil intake man. warped, removed and clean edges, file flat and rplace i.g.seal. Power flush system(full of oil/rust),replace w/coolant. Auto trans.power flush(fluids very dirty).Lube,oil,filter, said water in oil pan milky white, power flush oil system.Eng tune up, said coolant burning in cylinders.Replaced fuel filter.Power flush injection system.Flush/clean throttle housing(coolant in throttle housing)replaced gasket and air filter.Drove 200 miles and dealer put in gallon of coolant. 450 miles later eng.still runs rough dealer replaces vac. hoses,brake booster hose,starter harness and assemble,sensor burned for oil lamp and wire harness,rmoved harmonic bal. to repair wire from cluster to sensor. I wont drive the car and afraid by the sound it might blow up. Please help me.
Re: 93 6cyl 3.3 clunking eng noise
Welcome to the forum.
It sounds like your engine has gone to hell in a handbasket. ![]() If you had an internal LIM failure, I'm guessing the clunking is from your bearings being bad (eaten by the coolant). If that's the case, continuing to run your engine could result in bearing failure / seizing, and then your engine would be completely toast. |
Is there anything I can do to the engine or do I have to replace it? Someone said it sounded like it blew a rod? I dont know what that means exactly.
i blew a rod in my cavalier
i used to own a cavalier, and i blew a rod, the third one to be exact, and i know EXACTALLY how to fix it.. one of the few things i do know,
the engine is gone gone if you DID blow a rod, butttt if you can find a highschool around you take it to their autoshop and donate the car to them, they will rebuild it, it will take a whole school year, but they will get it working u just pay for parts, it works really good if you don't know what your doing, and then when their finished they will give the car back, but if the rod is shot, then you should hear a loud ( even louder when you give it gas) almost like a lawnmower with no exhaust, if so try the highschool, |
no exhuast? i mean a muffaler
i mean a lawnmower with out a muffler! my bad
