Old 11-10-2005, 06:36 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question TB Spacers / Twisters
http://cgi.ebay.com/ebaymotors/OBX-T...spagenameZWDVW
Do these work? It's supposed to move the air in a circular motion. Of course, when air is moved/pushed it condenses, thus making it colder. Does it really 'twist' the air though? Is it worth it? Anyone got one? Thanks!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-10-2005, 06:58 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I hope you noticed that was for the N/T spyders only. I doubt they do much. Maybe 1-2 hp.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-10-2005, 07:04 PM
david-b's Avatar
Dave is THAT guy
Re: TB Spacers / Twisters
I was just asking in general. It doesnt seem to hard to make em neither.
75 Monte Carlo
Old 11-10-2005, 08:26 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
I've heard good reviews(sometimes) about those in trucks but never heard about someone putting one in a car before. It sounds like that cyclone thing which doesn't work at all...
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 11-10-2005, 08:29 PM
david-b's Avatar
Dave is THAT guy
The clyclone is a little blade 'fan' actually blocking up the intake pipe. The spacer itself has grooves that make the air then spin. There is nothing blocking the airflow.
75 Monte Carlo
Old 11-11-2005, 12:16 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I dont think they do anything. That just on the outside and would probably just cause more turbulence than spin. The turbulence may help, but I wouldnt think it would help you out at all.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-11-2005, 03:12 AM
Skugulgurk's Avatar
Skugulgurk Skugulgurk is offline
I can't imagine how that would help. Spacers on carburetors are to give the A/F more time to mix and more time for the fuel to completely atomize. And then their whole "vortex" idea will get diffused as soon as it makes the 90-degree turn into the intake runners. The only benefit I can see is that it would use Bernoulli’s principal to draw in more air. But you could just get your throttle body ported for less than that price and it would have more of an effect. That's just my two cents.
99' eclipse GS 420A !!!TURBO!!! Hahn kit installed. still on stock everything else, including exhaust.
I know it's taking FOREVER to finish the write up but the bands been taking off lately killing my free time. I've got some pictures posted though if you want to check it out.
www.angelfire.com/indie/kbracing
Old 11-11-2005, 04:35 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
my friend had one of those on his neon before he turbo'd it. he claimed he noticed a difference in performance...and it also sounded like a turbo spooling when he accelerated.
Old 11-12-2005, 02:41 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
that won't do a god damn thing, you can't cool air by spinning it and compressing air RAISES its temperature, not lowers it.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 11-12-2005, 01:47 PM
david-b's Avatar
Dave is THAT guy
MAking air condense makes it colder. By spinning it, it does condense the air... thus making it colder.
75 Monte Carlo
Old 11-12-2005, 03:04 PM
drdisque's Avatar
dude, did you never take 11th grade chemistry?
First of all, you can't "condense" air by spinning it. Consensing something means taking the water out of it, spinning air doesn't take the water out of it.
Compressing air increases the temperature, its called "ideal gas law" look it up.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 11-12-2005, 07:33 PM
Skugulgurk's Avatar
Re: Re: TB Spacers / Twisters
Actually to "condense" means to increase density.
That is correct. The ideal gas law says that Temperature, pressure and volume all affect one another
This is the formula for the ideal gas law.
P V = n R T
P = pressure
V = volume
n = number of gas molecules
T = temperature
R = universal gas constant
So if we rewrite the equation
PV
----- = T
nR
You can see that an increase in Pressure will increase Temperature
Old 11-12-2005, 09:59 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Re: Re: Re: TB Spacers / Twisters
P V = n R T
P = pressure
V = volume
T = temperature
PV
----- = T
nR
LOL- Good JOB man!! LOL I just learnt that in general chemistry. Got a 57 on the test. Boy was i pissed!
Old 11-13-2005, 03:03 PM
david-b's Avatar
Dave is THAT guy
This is what I know from doing research on Intake Manifolds. Was looking at getting an aftermarket one. Did a lot of research of how air works when flowing and all.
The aftermarket IMs (the ones that are totally smooth), don't do anything for N/A cars that don't push out a lot of hp because the insides are totally smooth. The stock IMs are rough and bumpy. This is pursposely made like that so the air flowing through them bounce off the little grooves and bumps, making it move slower, but it gets denser and colder. The smooth pipes allow the air to free flow right through 'as is'.
I would imagine it's kind of the same with the spacer. Here, it does have grooves specifically designed to rotate the air. As the air is now moving even more, it would then bounce even harder off the little bumps and grooves of the IM, making it colder as it flows then into the engine.
Also with the 'twist' design to the spacer, the air (theroritically) spins in a vortex so the air is being pulled in faster to the engine. The bumps of the IM will still slow it down, but the air is flowing faster in the first place.
I'm no science major, but from the research I've done, this is what I've seen. Not being a dick, just posting what I've seen.
75 Monte Carlo
Old 11-13-2005, 05:53 PM
Thor06's Avatar
Jizzed In My Pants
The bumps are there to make the air churn around more so the fuel gets more evenly mixed, not so that it gets colder. I am willing to bet those shallow ass grooves arent deep enough and the spacer isnt long enough to get the air to spin, they will act just like big versions of those bumps in the intake manifold. So yes, it may help (very little if any) to have that spacer but it wont be because of spinning the air, it will be because the air was given more bumps to go around to give it more turbulence to better atomize the fuel.
