Old 11-10-2005, 06:07 PM
baggyshorts80 baggyshorts80 is offline
Unhappy alternator replacement
hi....new to this forum, but it seems like it's pretty cool and has alot of talented people out there. my daughter has a '97 ford escort, and i dont know what kind. however....she needs to replace the alternator. from what i can see and read in here, that car has one serpentine belt. is this true, and how hard is it to replace it? can someone kind of walk me thru it? pics would help, (if available) once again, thanks for all ur help! baggyshorts
Old 11-10-2005, 06:18 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: alternator replacement
Hi on these cars its super easy all you need is a 3/8 breaker bar to (pry)move the belt tensionier out of the way and then remove the belt Alt is pretty easy also. See autozone.com for pics and a how-to that they have up.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 11-11-2005, 06:22 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
While you're at it you might want to try and determine how old the timing belt is. I still have the original alternator. 263,000 miles and going strong.
Nevada Tumbleweed
Old 11-11-2005, 09:10 AM
rbsteve rbsteve is offline
its very easy on your car. The alternator is at the top front of the engine and all the bolts and wires are readily accessible. I changed the belt in ym escort last weekend, took about 20 minutes in all. Might be useful to have someone pull on the breaker bar while you work the belt off the first pulley. Then just unbolt and unhook the alternator and put the new one right back in the same place.
Old 11-11-2005, 01:11 PM
chevyn0va1's Avatar
I used a bungie cord wrapped around the breaker bar and the pop rod of the hood.
