Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-10-2005, 04:59 PM
tims95neon tims95neon is offline
95 neon turning problem
I have a 95 plymouth neon sport 2.0 and when i turn the engine revs up and this only happens when i trun. I changed my spark plugs, replaced valve gasket and tranmission pan gasket. I did the key dance and the only thing that comes up is 02 sensor. I was wondering if anyone could help me wit my problem.
Old 11-14-2005, 03:49 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 95 neon turning problem
Try and get the "P" code using an OBD II scanner so you can determine which O2 sensor it is. You have 2, one upstream and one downstream. The upstream is usually the one that fails first or more often.
Old 11-14-2005, 03:53 PM
Re: Re: 95 neon turning problem
I will try doing that. Does advance or autozone have one of those scanners? Thanks for the reply and I hope that works.
Old 11-14-2005, 04:37 PM
Re: Re: Re: 95 neon turning problem
Autozone does it, I don't know about Advance Auto.
Old 11-14-2005, 06:49 PM
k thanks alot
