Old 11-10-2005, 01:59 PM
armstrong armstrong is offline
engine code
Just wondering if anyone code tell me what a check engine code 1518 could be. Its on a 2001 F150 XL V6 4.2L standard.
Old 11-10-2005, 02:11 PM
Re: engine code
OK from what I have found it means Inlet Manifold Runner Control Stuck Open. Can anyone clarify this for me or explain what to do. I would apreciate it.
Old 11-10-2005, 06:36 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: Re: engine code
No personal experience. From what I have read "IMRC: a system that controls a second set of throttle plates that open above 3000 rpm's for additional airflow into engine (Intake Manifold Runner Control)."
Sounds like a problem with linkage, solenoid, wiring, etc.
Hers are a few links.
http://www.cartrackers.com/Forums/li...star/2069.html
http://mustangandfords.com/techartic...ap/index3.html
Old 11-14-2005, 03:17 PM
riverwakerider riverwakerider is offline
Re: engine code
the intake manifold runner control is an eletrical solenoid that open the secondary runners. It is located at the back of the engine attached to the lower intake. You have to remove the upper intake to access it. Be sure to get the plastic clips that hold the rods to the intake they break easily when removing
